Outside square corner
I need to cut rec.outside with square corner. never had a problem before.I know how to setup for a square corner but after creating profile it shows a radius corner. can you help.
woodman29
woodman29
Re: Outside square corner
Welcome to the Vectric Forum WoodMan. I'm sure we can help but we might need some more info.woodman29 wrote:I need to cut rec.outside with square corner. never had a problem before.I know how to setup for a square corner but after creating profile it shows a radius corner. can you help.
woodman29
So your doing a profile cut on the outside of the selected Vector with a endmill. But your corner shows up in the preview as a Radius? Is this correct?
Do your vectors intersect at a 90?
That is correct They are at 90 .The rec was created in cut 2D bu putting in exact measurement.
Can you post the file or a portion of it so we can look at it.?woodman29 wrote:That is correct They are at 90 .The rec was created in cut 2D bu putting in exact measurement.
( HHO#1 REC 2 )
( Mach2/3 Postprocessor )
N20G00G20G17G20G90G40G49G80
N30G70
N40T5M06
N50G00G43Z0.7874H5
N60S3000M03
N70G94
N80X0.0000Y0.0000F80.0
N90G00X-2.6250Y-3.5000Z0.2362
N100G01Z-0.0000F7.9
N110G01X-2.6249Y-3.5056Z-0.0002
N120G01X-2.6245Y-3.5112Z-0.0004
N130G01X-2.6238Y-3.5170Z-0.0005
N140G01X-2.6229Y-3.5227Z-0.0007
N150G01X-2.6217Y-3.5286Z-0.0009
N160G01X-2.6202Y-3.5344Z-0.0011
N170G01X-2.6184Y-3.5402Z-0.0013
N180G01X-2.6162Y-3.5460Z-0.0015
N190G01X-2.6138Y-3.5518Z-0.0017
N30G70
N40T5M06
N50G00G43Z0.7874H5
N60S3000M03
N70G94
N100G01Z-0.0000F7.9
I apoligize Woodman, i should have been more specifc. Can you post the .crv file?
I see you are using Mach....Is your machine set to Constant velocity or Exact stop.
it is on constant .itried it on exact stop .no help I have the crv filebut i cannot get it in this answer.It showsa perfect rec.with square corners.that is the vectors.The tool path is outside like it should be except with rounded corners In software button is on for square corners.Ihave made squares and rec. lots of times before.something might have gone wrong in software.
Thanks again
Roland
Thanks again
Roland
I think you are getting confused by the shapewoodman29 wrote:I need to cut rec.outside with square corner. never had a problem before.I know how to setup for a square corner but after creating profile it shows a radius corner. can you help.
woodman29
See the picture below.
Both the profiles in red will perform a square corner.
The one on the left will do so as it moves in two linear moves.
The one on the right will do as it it rolls round the fixed corner [ shown in yellow ] then moves as a linear move.
John S.
John S.
Nottingham England.
Nottingham England.
I wish I could help you out but without seeing the file I'm drawing a blank.
You can save the file with the .crv extension by clicking _>File / save as.
In the Vectric forum you can attach the file below the area where you type. Under the Header "Upload attachment. Just click browse and then locate the file on your hard drive and then click add the file.
When you submit your post the file will show up as a attachment.
If you don't wish to post the file you can email it to me
CRFultz at gmail.com. and I'll take a look at it and machine it if necessary and try to identify the problem.
Chuck
Chuck
I would like to thank everyone who has helped.Ihave not cut the piece yet but have run it in mach and it looks like it is cutting round corners.I will cut a sample tomorrow and let you know how it works.Cut 2D is the best software i have used.For the price you cant beat it.
Roland
Roland
Hello
Today i cut a rec on machine and it did cut square corners.Thanks again I am sorry to be a .bother.I do appreciate all the help
Roland Rogero
Roland Rogero
- tamathumper
Glad to hear it came out OK.
I should have keyed on your description about square OUTSIDE corners, which matches my recent thread about cutting square corners with round cutters and peoples' responses thereto.
Allen
Allen
CNC: www.bitcarving.com; Hybrid 4x4, RockCliff, Mach3, Vectric Aspire 2 + Wildlife Scenes 1.
