Is there a bug on the toolpath? PROBLEM SOLVED
On the 2D design is looking fine but when I preview in the toolpath is all off. I don't know is a bug or I did something wrong.
- Model of CNC Machine: shobot 48x96
all I did was recalculate the toolpaths. it looks like you moved things around. but I opened it in vcarve pro so I may have missed something.
also is your material 4" thick?
why do pockets? thats slow and a waste. also I would not name the outside cuts pockets since they are profile cuts. all you need to do to cut these out is select all of the parts choose profile cut to the outside and they will all be cut out right with one toolpath.
