CNC Not Cutting at anchor point xyz-0-home
Postby lward1988 » Thu Jul 25, 2019 8:44 pm
I did my first test cut on the machine today, however it cut it in a crazy spot! Instead of cutting at the lower left hand "home" position, it went up about halfway and cut it up there...thank gosh its a test. The machine did not cut all the way through (setpoint .25" deep) but it did cut the OD perfect in size, just not deep enough...I feel its a homing thing but i'm unsure. Any insight?
lward1988
Model of CNC Machine: laguna swift 4x8
Re: CNC Not Cutting at anchor point xyz-0-home
Postby mtylerfl » Thu Jul 25, 2019 9:04 pm
1) Where did you set your XYZ zeros when you created your actual project file?
XY
- which corner or in the center of the virtual material?
Z
Top or Bottom of the material?
2) Where did you set your XY zeros at your machine and where did you set your Z zero (top of material or bottom of material)?
Postby lward1988 » Fri Jul 26, 2019 9:10 pm
I went back through some "origin" videos and figured out my issue was quite common. From the factory they had the start point around the middle of the table. I ended up setting one of my origins to the back left of the table for load/unload and set the front left corner as my primary "start" point. Thanks again!
lward1988
Postby mtylerfl » Fri Jul 26, 2019 9:29 pm
Glad to know you got that sorted out. Good job!
Return to Cut2D - General
Users browsing this forum: MarkJohnston and 3 guests
