Unwanted tool path.
Unwanted tool path.
Postby helensdad » Sun Jun 16, 2019 12:12 pm
Hi, I am trying to set up to cut out the part in the picture from aluminium but for some reason it wants to join the two holes together, which I don't want. How can I stop it from doing this?
helensdad
Model of CNC Machine: Oozenest Ox 500 x 750/Openbuilds Minimil
Re: Unwanted tool path.
Postby mtylerfl » Sun Jun 16, 2019 12:38 pm
Please, will you post your actual file so we can help you troubleshoot?
Postby highpockets » Sun Jun 16, 2019 12:41 pm
Can you post the project file?
LOL!!!! Michael beats me again.... :lol: :lol: :lol:
Postby helensdad » Sun Jun 16, 2019 1:54 pm
OK, I actually deleted it, I am however having trouble still. I want to cut outside the line, but it says there are 12 unsuitable vectors. I will post what I have done. IThis is the first file I have tried to create myself...
helensdad
Postby helensdad » Sun Jun 16, 2019 2:04 pm
Z laccutator finger.crv
(588 KiB) Downloaded 28 times
helensdad
Postby scottp55 » Sun Jun 16, 2019 2:24 pm
You just needed to Join those vectors.... lots of different ways, but Edit tab..select Open Vectors....Deselecting that bottom Polyline by holding Shift down..and then Joining them is good for Starters:) OH the poor cat:)
Z laccutator finger s1.crv
(587.5 KiB) Downloaded 21 times
scottp55
Postby helensdad » Sun Jun 16, 2019 2:32 pm
Cheers Scott, many thanks. The poor cat?
helensdad
Postby scottp55 » Sun Jun 16, 2019 2:44 pm
No problem....I was actually putting off emptying my Dust Deputy canister and vacuuming behind the machine :)
WAY more than one way to skin that cat:)
Keep going...it get's easier!
Time to mask and goggle up :(
scottp55
Postby helensdad » Sun Jun 16, 2019 6:47 pm
What went wrong?
I got the tool paths sorted out but something went wrong when I tried to cut it. It cut the two mounting holes, nearly all the way through, then flew off to one side and proceeded to cut outside my piece of aluminium. When I ran the simulation in Cut2D it worked great. My machine did make a knocking sound before it developed a mind of it's own so maybe some obstruction caused it to miss a load of steps or something....
helensdad
Postby scottp55 » Sun Jun 16, 2019 9:43 pm
Post the file with toolpaths again, so somebody with a light machine can check speeds/pass depths and such?
"Knocking" sound, always seems to me like a Hard Stop was hit....It Always means steps will be lost! Virtually always the toolpath should be stopped by you immediately!!
scottp55
Postby highpockets » Sun Jun 16, 2019 9:52 pm
I'm with Scott, it would help to see the file. From the picture it looks like you're using a v-bit. Also you machine isn't very ridge for cutting aluminum, loss of steps is a big possibility.
Postby SteveNelson46 » Sun Jun 16, 2019 11:56 pm
Did you get X0 Y0 set to the same place as in the software?
SteveNelson46
Postby helensdad » Mon Jun 17, 2019 12:38 am
Work zero was set before starting machine. I was taking 0.25 mm passes, aborted before pass had finished, using 1/8" endmill. I will post file tomorrow.... Many thanks all!
helensdad
Postby helensdad » Mon Jun 17, 2019 11:07 am
Part.crv
(115 KiB) Downloaded 33 times
Here is the file I ran that resulted in the mess in the above photo....
helensdad
Postby Adrian » Mon Jun 17, 2019 12:15 pm
Your pass depth is set to 1mm not 0.25mm and, although I'm no expert on those type of machines, your feedrate is a lot higher than I've seen other people recommend especially at 1mm pass depth.
Next
Return to Cut2D - General
