First project...
First project...
Postby helensdad » Tue Jun 11, 2019 3:15 pm
I am stuck already! I am trying to make a name plaque for my daughter's horse stable, I have managed to get the text into an oval with a border, the whole thing cut from a rectangle of Ash. So, I need a toolpath with tabs around the outer oval perimeter the full depth of the material, 17mm. I then want to leave the outer and inner oval as is, same with the text, so I basically want to carve out all the material around the text to a depth of 5mm. When I create the toolpath and run the simulation, it carves the lot away or just leaves portions of the text. I would be most grateful for any tips. I am using Cut2D......
helensdad
Model of CNC Machine: Oozenest Ox 500 x 750/Openbuilds Minimil
Re: First project...
Postby Adrian » Tue Jun 11, 2019 3:23 pm
Create a pocket toolpath that consists of the text and inner oval. The outer oval is a profile toolpath.
Basically the same as this tutorial - https://support.vectric.com/tutorials/V ... video_id=2
Postby helensdad » Tue Jun 11, 2019 4:22 pm
Many thanks, I will do that. This is my first project, hopefully it will work out ok...
helensdad
Return to Cut2D - General
