Nesting
Nesting
Postby DGF » Mon May 20, 2019 12:12 pm
Hi there, I'm sure this is easy once you know how!
I'm cutting various size panels out for example 5 @720 x 505 3@ 364 x 505 9@ 720 x 560 etc etc
If I have drawings of each and want to nest say 5 - thats ok I can see how to do that.
Then I want to add another size panel to the same sheet and nest that with the first 5 panels - is this possible?
Many thanks
DGF
Model of CNC Machine: CKJ
Re: Nesting
Postby Adrian » Mon May 20, 2019 12:35 pm
You would select the 5 panels and the new one then re-nest.
You can also do it by creating both panels, setting the number you want to nest for each and then nesting.
You can't constrain the nest so that the first five panels go on there with the other panels afterwards unless you create a vector boundary based on the first nest.
Re: Nesting
Postby DGF » Mon May 20, 2019 1:12 pm
Thanks Adrian
how do you set the numbers for each seperate panel?
DGF
Re: Nesting
Postby Adrian » Mon May 20, 2019 1:16 pm
Select the panel in question. In the nesting form set the number of copies and press Apply. You'll see the number of copies displayed on the panel when you have the nesting form open.
Re: Nesting
Postby DGF » Mon May 20, 2019 1:28 pm
ok thanks i have done that but it always puts them on top of the previous ones - is there a way to select them all - so multiple panels of different sizes and shapes- and then it nests them all ont he cutting sheets in the best way?
DGF
Re: Nesting
Postby Adrian » Mon May 20, 2019 2:11 pm
Not sure where you're going wrong but all you need to do is to set the number of copies of each panel you want, select everything you want in the nest and then nest. If there is an existing nest then it will warn you that it will be replaced. If the previous nest was only on one sheet rather than multiple then you would need to delete those vectors/panels first as the nest will just leave them where they are if they aren't part of the new nest.
These tutorials may help:
https://support.vectric.com/tutorials/V ... ideo_id=93
https://support.vectric.com/tutorials/V ... ideo_id=88
Return to Cut2D - General
