Toolpath problem - Outside/Right is offset
Postby Slaney » Mon May 13, 2019 6:32 pm
Hi, I am having problems when trying to use the “Outside/Right” toolpath from 2D profile option. The preview of the toolpath shows not only that the path does not follow the 6 pieces to be cut from the plywood, but that it applies a 3.5 cm offset around the combined 6 polygons. Any idea what is happening here? See attached images. If I select the “on” toolpath, it displays the anticipated paths. Any guidance is appreciated,
Thanks.
Outside/right
Slaney
Model of CNC Machine: Shapeoko 3 XXL
Re: Toolpath problem - Outside/Right is offset
Postby Rcnewcomb » Mon May 13, 2019 6:53 pm
If you could upload your CRV file that would help us to help you.
Postby ger21 » Mon May 13, 2019 7:23 pm
It looks like the parts are too close together for the 1/4" tool (6.35mm) to fit between them. Create toolpaths for each part separately, and you'll see how they overlap.
ger21
Postby Slaney » Tue May 14, 2019 1:31 am
Thanks, I will add more space between parts and see what transpires.
Slaney
Return to Cut2D - General
