Cut#D file to Aspire file?
Postby Alydar » Thu May 09, 2019 1:09 pm
hello All -
I have a very old version of Cut3D, yes Cut 3D. :-)
My cnc operator uses Aspire and I am trying to save a file in Cut3D that they can cut with Aspire.
Any ideas on this?
Thanks!
Alydar
Model of CNC Machine: Shopbot
Re: Cut#D file to Aspire file?
Postby scottp55 » Thu May 09, 2019 2:01 pm
Here's a Partworks3D one from 2014(my very first 3D)....can't remember exactly how I imported the toolpaths, but it worked back then with VCP7....
And just opened it up with the Shopbot Edition of VCP 9.517...and it worked.
Maybe send him the Roughing and Finishing toolpaths, and see if Aspire will open them?
2019-05-09 08_56_05-VCarve Pro - ShopBot Edition 9.517 - 1.17.14 3D TESTBOARD.jpg
scottp55
Postby Adrian » Thu May 09, 2019 3:44 pm
If you toolpath the file in Cut3D and save it the V3D file can then be loaded into Aspire via the File/Import menu. This will load the toolpaths but you can also position the item as well in Aspire plus edit the feed rates.
Postby Alydar » Fri May 10, 2019 6:13 pm
Thanks guys -
I cannot save this as a v3d file out of cut3d - is there a general purpose file type that Aspire will accept if imported?
Alydar
Postby Adrian » Fri May 10, 2019 6:52 pm
Aspire can import several different 3D file types.
http://support.vectric.com/aspire-quest ... e-imported
Return to Cut2D - General
