Clearance around raised letters
Postby JW149 » Tue Oct 30, 2018 12:46 am
I am trying to clear an area around some raised letters on a sign.
I want to do it with a larger diam cutter (say 5mm) then refine the areas using a small cutter (say 2mm)
Is it possible to just attack the bits left by the larger cutter, and not spend 8 hours with a 2mm cutter doing it all again better?
A sort-of differential algorithm
If not possible with Cut2D then it that possible with Vcarve?
Or maybe there is a procedure I should know about.
All comments welcome, including a solution!
JW149
Model of CNC Machine: CNC_Design Mini-Muscle desktop
Re: Clearance around raised letters
Postby Rcnewcomb » Tue Oct 30, 2018 1:15 am
This video shows you how to do it: Pocket Toolpath Guide
The section you are most interested in begins at bookmark 2.Larger Area Clearance Tool
Postby JW149 » Thu Nov 01, 2018 12:59 am
Thank you. I did view all tutorials originally, but just forgot this. That has saved me several hours on machine time.
JW149
Return to Cut2D - General
