Path guidance
Path guidance
Postby bcontrol » Fri Oct 19, 2018 2:29 pm
Good Morning
How to orient the paths in sequence to right for example.
It's possible?
sorry about my English
thanks :D
bcontrol
Model of CNC Machine: cutter
Re: Path guidance
Postby Adrian » Fri Oct 19, 2018 2:51 pm
You'll need to explain a bit more what it is you want to do and ideally attach a file.
It could be that you need to close the vector but without knowing what the end result should be that could be wrong.
Re: Path guidance
Postby highpockets » Fri Oct 19, 2018 3:28 pm
If you are looking for the cut path to be from the vector on the left then move to the right vector and start cutting use the node editing tool to change the starting node as marked.
Hope this makes sense.
Re: Path guidance
Postby bcontrol » Fri Oct 19, 2018 3:34 pm
I am with version 8.517 and I noticed that in version 9.5 it is possible to edit the starting point of cut ...
But I can not update ...
bcontrol
Re: Path guidance
Postby Adrian » Fri Oct 19, 2018 4:06 pm
You can edit the starting point of a cut in 8.5 as well.
Return to Cut2D - General
