starting point
starting point
Postby cromag27 » Mon Sep 03, 2018 8:56 am
help! so i'm trying to get all these little pieces (photo 1) to start in the upper left corner. no matter how/what order i select them before creating the toolpaths, they will not start in that corner. sometimes the start points actually change position depending on how many i select at a time before creating the toolpath. can i get some help with this issue? thanks!
cromag27
Model of CNC Machine: nwa shark hd3 ext mod
Re: starting point
Postby Adrian » Mon Sep 03, 2018 11:42 am
In the profile toolpath make sure that you have "Show advanced toolpath options" checked. Now go to the set of tabs in the 6th box down and click the Start At tab. Make sure "Keep Current Start Points" is selected to force the toolpath to start at the green start node on the vector.
In the case of your shapes you could also use the "Move start points..." option and select the top left.
Re: starting point
Postby cromag27 » Mon Sep 10, 2018 1:18 am
move start points...bingo! thanks a lot!
cromag27
Return to Cut2D - General
