engraving anodized aluminum
Postby Mofosheee » Mon Jul 23, 2018 2:09 pm
Does anybody have any advice or experience with engraving anodized aluminum using a 0.005" bit.
My concerns are that of the longevity / durability of the bit v.s. the hardness of the surface. Thank you
Mofosheee
Re: engraving anodized aluminum
Postby Mobius » Mon Jul 23, 2018 2:19 pm
When engraving any material with a rotating carbide tip that small, making sure your machine has as little flex and run-out as possible is key. Otherwise the tip will just break off.
Personally, I think this sounds like a job for a diamond drag bit. This is done often with great results.
Connor Bredin
www.distinctive-concepts.ca
Mobius
Postby dhellew2 » Wed Jul 25, 2018 12:04 am
Cooling helps too, for small bits compressed air works really well. Just spray a small amount directly at the point of contact. Dale
Dale
dhellew2
Return to Cut2D - General
