A very good day to you all!
As a former user of other Cam software, I was used to the possibility to very quickly set a new x0y0 position by clicking with the mouse on a point on the drawing. (after choosing 'set zero')
I use this often because I have many small parts on one dxf drawing and I want to use every part of the expensive wood.
Also when some work went wrong, I could easily mill one part of the multiple parts again.
This was my workflow:
1. choose a part to mill and set the xy to zero by simply clicking on the lower left of the part. (after choosing 'zet zero')
2. save the file with only 1 toolpath of the part to mill
3. set the router to the point on the wood and zero
Now I have to position the mouse on the part of the drawing and remember the x and y position.
then go to work setup and click on offset and enter the values
It is doable of course but I was spoiled with an easier way. (now I'm spoiled with Cut2D, never looked back )
But am I overlooking an existing option in Cut2d Desktop to enter the current mouse position in the xy fields instead of remembering them??
thanks!
Easy way to set xy position?
- Mark
- Vectric Staff
Re: Easy way to set xy position?
Hello,
No, I am afraid that there is no way to set the X,Y, 0,0 position, in the way that you have mentioned.
Cheers,
Mark.
Cheers,
Mark.
When I cut multiple parts in carbon fibre sheet which is very expensive as well I do a similar thing but I use the ability of my control software to repeat a cut at any XY position but using a file with a different XY zero position.
I don't know what control software you use but perhaps you have a similar facility.
- highpockets
A bit fiddly, but you could get the center coordinates of the part to cut out and enter an offset in XY Datum Setup.
- Xxray
Not exactly what you have in mind but I save often cut parts and position as a home position and I can easily zero on that position any time in seconds and start cutting.
For instance I do alot of 10" plexi mirrors, so I index a spot on the board where I will put it there every time, find the center and save that as a home position, so there is no fiddling about when I do another mirror.
[Nothing to do with vectric software btw, all in control wincnc in my case]
Doug
Great to have so much knowledge available in this forum!
Thank you all very much, I will look if my control software will mill at a different position than the gcode coordinates.
(I use EdingCNC)
Cheers,
Erik
(I use EdingCNC)
Cheers,
Erik
