Angled Tool paths
Angled Tool paths
Postby FrancisM » Mon Mar 19, 2018 11:30 am
Possible tool path
Hi I have a problem
Working in Cut2D Desktop I want to shape the straight section of a guitar neck based around points given by the standard eclipse equation.
Can I specify points directly for Z, Y and X. I want to work with the neck positioned along the Y axis (also central axis of the guitar neck) with a fixed length between start and finish points on the Y axis. Then mirror the tool paths for the other half of the neck?
See attachment: Image is looking down the Z axis, perpendicular to the X/Y plane. Starting at 'O' (origin point off the neck) move to Y1, offset to Y1,X1 move to Y2,X2 cutting down to Z1 depth then repeat for next Zn, Xn, Yn positions.
Is it possible to specify single or multiple tool paths as co-ordinates?
Is there a specific format these should be entered in?
Many thanks
FrancisM
Model of CNC Machine: Oosnest WorkBee 750 x 750
Re: Angled Tool paths
Postby FrancisM » Mon Mar 19, 2018 2:16 pm
These two illustrations I hope give a better idea of what I'm trying to achieve...
FrancisM
Postby FrancisM » Mon Mar 19, 2018 11:16 pm
Getting there. Using the ellipse equation has worked for this test, Need to increase the resolution adding more steps...
FrancisM
Postby PaulRowntree » Tue Mar 20, 2018 1:28 am
Hi Francis
I have never used Cut 2D, but how do you do this? Are gadgets enabled in the Desktop version?
Paul Rowntree
PaulRowntree
Postby kstrauss » Fri Mar 23, 2018 7:56 pm
Could you please post some details of how you generated your 3D toolpath?
kstrauss
Model of CNC Machine: Tormach PCNC770
Postby adze_cnc » Mon Mar 26, 2018 5:56 pm
From the images I surmise:
1. there are no 3D toolpaths just a number of 2D ones
2. this was accomplished by manually figuring out the x, y, z, co-ordinates of quadrilateral shapes that are then pocketed to the particular z depth
adze_cnc
Return to Cut2D - General
Users browsing this forum: No registered users and 9 guests
