Save in another format
Postby cusoak » Sun Dec 24, 2017 5:12 pm
Can something that is created in cut2d be saved in another format so it could be used on a Silhouette cutter, or would there be a post processor to save the cut file too. for that cutter
Jeff
cusoak
Re: Save in another format
Postby Adrian » Sun Dec 24, 2017 8:11 pm
You would need to export the vectors as DXF (select them and use the File/Export menu command). You can then load the DXF file into the Silhouette cutting program.
Return to Cut2D - General
