Removing line
Removing line
Postby cusoak » Thu Dec 21, 2017 3:47 pm
In the attached file this showers a cut sky line of columbus. I would like to know how to remove the bottom line that runs from side to side.
I want to be able to add longer side to make it fit a larger height board ,so I can put script under it and then cut it out.
Jeff
z columbus silhouette.crv
(312.5 KiB) Downloaded 86 times
cusoak
Re: Removing line
Postby dah79 » Thu Dec 21, 2017 4:40 pm
Go to node edit, place cursor on bottom line corners, press c. Then click back on bottom line and delete.
z columbus silhouette_rev.crv
(308.5 KiB) Downloaded 78 times
Dave
dah79
Model of CNC Machine: FLA Saturn 4x4
Re: Removing line
Postby Adrian » Thu Dec 21, 2017 4:54 pm
You could also hover over the lines in node edit mode and press D.
Re: Removing line
Postby cusoak » Thu Dec 21, 2017 7:22 pm
Thanks , I figure is would be something easy.
Jeff
cusoak
Return to Cut2D - General
