different cutters
different cutters
Postby David Tolley » Fri Dec 08, 2017 11:33 am
Hi All
completed the first test cut on the Workbee which went well but with a couple of minor errors (toolpath left a ridge to the bottom of the work piece, which I have put down to material movement, we wait and see on that one.
todays obvious question from the newby as follows:
I wish to cut out a shape with a 0.25mm cutter, however I then wish to add txt with a 0.125 cutter, can this be done in one design or do I need to copy the design and add the txt only on design no 2 with the smaller cutter, or do I use the filter option or how do I do this please.
Many Thanks for your help and advice
D
David Tolley
Model of CNC Machine: workbee
Re: different cutters
Postby Adrian » Fri Dec 08, 2017 12:30 pm
The whole thing can be done in one Cut2D file but you'll need to generate two cutting files. One for the 0.25mm bit and one for 0.125mm bit.
Return to Cut2D - General
