vanishing toolpaths
vanishing toolpaths
Postby gcb0909 » Mon Nov 13, 2017 8:47 pm
Hi all, a little bit of help required, when I go to view all toolpaths in Cut 2D, I select the toolpaths hit Review button but nothing shows up, in the 3d Tab, any help gratefully received :D
gcb0909
Model of CNC Machine: KJ 3030
Re: vanishing toolpaths
Postby Adrian » Mon Nov 13, 2017 9:18 pm
What's the Review button?
Which button are you pushing and how have you selected the toolpaths? Selecting and visibility are different things.
Postby gcb0909 » Mon Nov 13, 2017 9:29 pm
Hi Adrian, I used wrong terminology, I highlighted all my toolpath, then went to PREVIEW ALL TOOLPATHS, but the toolpath checked boxes became unchecked and nothing showed up in the animated view in 3D view. I have gone back through the tutorial and checked all the settings..... I think
gcb0909
Postby Adrian » Tue Nov 14, 2017 9:07 am
Preview All Toolpaths will uncheck all the toolpaths one by one as it displays them so that's normal. If nothing is showing up the most likely cause is that the cut is too shallow to appear. If possible the best way to solve this would be for you to attach the actual Cut2D file here. If that's not possible (copyright, commercial reasons etc) then some screenshots of the toolpath settings etc would help.
One thing to try is to increase the preview resolution. You can adjust that on the Toolpaths>Preview Simulation Quality menu.
Postby gcb0909 » Tue Nov 14, 2017 10:37 am
Hi again Adrian, I have increased the resolution but to no avail, this is only happening on new files, my older ones seem to be ok,
I have attached the file for you,
lovers.dxf
this is it
(136.66 KiB) Downloaded 139 times
gcb0909
Postby Adrian » Tue Nov 14, 2017 12:39 pm
It's the actual Cut2D file (CRV) that is needed. The DXF previews fine for me but I don't know what material and toolpath settings you're using from that.
Return to Cut2D - General
