Tile help
Tile help
Postby cromag08 » Fri Sep 08, 2017 3:17 am
I have a nwa shark hd3 extended bed. How can I use the tile feature to cut pieces larger than 24" if I don't need to move the actual material. I've never used timing at all, so any help would be appreciated.
cromag08
Model of CNC Machine: mydiycnc
Re: Tile help
Postby highpockets » Fri Sep 08, 2017 3:38 am
Re: Tile help
Postby cromag08 » Fri Sep 08, 2017 4:10 am
highpockets wrote:Have you watched this tutorial?
http://support.vectric.com/tutorials/V9 ... ideo_id=33
Yes.
cromag08
Re: Tile help
Postby highpockets » Fri Sep 08, 2017 5:51 am
A little more information would be helpful. If you don't need to move the material why do you want to use tiling?
Re: Tile help
Postby cromag08 » Fri Sep 08, 2017 5:59 am
highpockets wrote:A little more information would be helpful. If you don't need to move the material why do you want to use tiling?
2d desktop makes me. My issue isn't that the bed is too small, it's the limitation in the software. I don't know if the tiling feature would work because I don't need to move my material at all. And the video doesn't show how to actually cut the individual tiles.
cromag08
Re: Tile help
Postby FixitMike » Fri Sep 08, 2017 7:17 am
If your tiles are 20" high, Carve the first tile, Jog your gantry to Y=20", reset Y to 0, and run the second tile.
Don't forget that for tiles X0, Y0 is at the lower left corner.
I can't believe NWA provided software with your machine that wouldn't use the full Y movement.
FixitMike
Re: Tile help
Postby cromag08 » Fri Sep 08, 2017 1:43 pm
FixitMike wrote:If your tiles are 20" high, Carve the first tile, Jog your gantry to Y=20", reset Y to 0, and run the second tile.
Thanks, that makes sense.
cromag08
Return to Cut2D - General
