60 Degree v-bit on fonts.
Postby auga » Mon Jun 19, 2017 4:20 am
Thanks in advance for assist.
I have the 2d cut and wish to cut a simple true font with a v-bit perhaps using 60 degree?
I want the end results to have a angle vs straight sides. I having problems grasping this idea
how to do this so the bottom of the fonts are clean.
I have not been able to find any videos, etc on this. Any pointers?
auga
Model of CNC Machine: TinyG - Homemade
Re: 60 Degree v-bit on fonts.
Postby Rcnewcomb » Mon Jun 19, 2017 6:13 am
Cut 2D doesn't support the 2.5D VCarving / Engrave toolpath. You need V-Carve or Aspire for that. ->Product Comparison
The closest you can come is using a pocket toolpath with a V-bit to produce raised letters with angled sides.
Model of CNC Machine: Shopbot, CAMaster
Postby auga » Mon Jun 19, 2017 9:22 pm
I want to opposite of raised letters. I want to cut the font so its lowered. But cut it was a v-bit/engraved bit so the sides have a small angle.
The issue is caused when having a non-flat bottom engraving bit which the letter in the center takes additional cutting passes. This can cause a line in the
center from the point, cause very unclean letter bottom of the wood.
auga
Postby Rcnewcomb » Mon Jun 19, 2017 9:28 pm
Can you post a photo and/or an example Cut2D file?
Postby IslaWW » Tue Jun 20, 2017 12:02 am
auga...
You are describing to a tee what the vcarve toolpath does with a vbit. You will need VCarve or Aspire to do that. The feature is not available in Cut 2D
CNC Technology & Training
Control & ATC Retrofits
IslaWW
Model of CNC Machine: SideWinder ATC & CNC Mill on WinCNC
Postby auga » Tue Jun 20, 2017 5:15 am
Understand that is what vcarve does well. Plan to upgrade at a later date.
But if you selected a font vector. Then selected the Engrave option in tool path in 2dcut. Then
you can selected from your tool database V-bit 90, 45, 60 etc. It allows you selected the degree of the cut. Or
even select cross hatch. Allowing you place a texture pattern at the bottom of the cut out font within the
the text engrave option. This works well with other vectors besides just fonts.
I discovered that onsrud engraving bits has for example a 60' bit with a flat tip @ .09 inch (2.25mm) 1/4" shank p/n 37-15 for example.
This should allow you to have a flat bottom on the font I cut vs the texture pattern.
I made some simple test cuts on scrap walnut today using a 90' 1/4" v-bit. Selected a 30' cross cut pattern as well
as a cross cut. Both came out very nice with different results.
I ordered a flat bottom bit, will wait results.
If you like for me to post a simple pic, let me know.
auga
Postby kstrauss » Wed Jun 21, 2017 5:52 pm
How about using two bits: one with a flat bottom and the other a V-bit? Generate a pocket or profile toolpath and specify a clearance offset for the flat bit. Then use the V-bit to cut the sides of the letters. You may want to specify a depth such that the point of the V-bit is slightly off the bottom of the pocket. I do this all the time to chamfer pockets.
kstrauss
Model of CNC Machine: Tormach PCNC770
Return to Cut2D - General
Users browsing this forum: sylvan356 and 7 guests
