Safe Z setting
- Model of CNC Machine: TinyG - Homemade
Safe Z setting
How do you change the safe Z setting? The amount that is safe they can move the Z. The help said to change it the material setup. But edit --> job setup has no Z safe.
- IslaWW
Re: Safe Z setting
Open the material setup dialog at the top of the toolpath tab, press setup
Gary Campbell
GCnC Control
GCnC411 (at) gmail.com
GCnC Control
Re: Safe Z setting
Thank you
- Model of CNC Machine: Stinger 1 and Mabel, both with 4 axis
Re: Safe Z setting
This tutorial will give you a good walk through setting up a job on your CNC
http://support.vectric.com/tutorials/V8 ... ar_GS.html
Euan
Euan
Re: Safe Z setting
I take a look at it again. I got the job setup and material setup confused. Changed the z safe and works now.
