converting PDF files / making gears
Postby waltneu » Fri Mar 24, 2017 9:15 pm
I'm trying to get Cut 2D Pro work on a gear. I loaded the picture of a gear (PDF file) into Cut 2D but it treated the picture as one object. I looked in the faqs saw where Vector Magic was mentioned
so I gave it a try. Vector Magic says my PDF file doesn't include vector object?!
I really want to cut clock gears with my router before I pull all my hair out.
walt
waltneu
Model of CNC Machine: mach 3
Re: converting PDF files / making gears
Postby Adrian » Fri Mar 24, 2017 9:30 pm
PDF files can contain bitmaps or vectors or a mixture of both. Cut2D can import both but bitmaps will need to be manually or automatically traced to produce vectors before toolpaths can be created.
Vector Magic is a bitmap tracer that does the same job as the automatic trace function within Cut2D but with a few more options.
Postby adze_cnc » Fri Mar 24, 2017 10:30 pm
My immediate question would be was PDF the source format for the gear? If not then perhaps the source format file might be a better one to use?
adze_cnc
Postby Rcnewcomb » Fri Mar 24, 2017 10:32 pm
Depending on what you want geargenerator.com lets you download an SVG file which can be imported as a vector.
gg_gear N18 D4.5 P4 PA27 @100.zip
(11.94 KiB) Downloaded 50 times
Postby Bobtail Farm » Tue Mar 28, 2017 12:23 pm
Perhaps you would review Gearotic, software.
Bobtail Farm
Return to Cut2D - General
Users browsing this forum: sparkyv65 and 4 guests
