Raised text in pocket
- Model of CNC Machine: Hobby laser engaver & CNC router
How would I create a raised text, or other pattern in a pocket? V8.0-8.5
- FixitMike
Re: Raised text in pocket
Draw a pocket outline around the text Select both the text and outline and apply a VCarve or profile toolpath. You will have a pocket cut leaving raised text.
- adze_cnc
Further to FixitMike's post. The attached images shows a two-level raised text in pocket.
The material is 3/4" thick. The top of the "T" is at 1/4" depth and the bottom of the pocket (yellowish colour) is at 1/2" depth.
Two toolpaths were created:
1. using only the vector in the "pocket" layer (depth 1/4")
2. using vectors in the "pocket" and "T" layers (depth 1/2")
I did this with VCarve as I don't have Cut2D installed anymore so posting the VCarve file might not be of use if Cut2D can't import it.
Steven
Steven
Thanks guys, work great with one change. In Cut 2D, after selecting both the box and text, I had to use pocket path, not profile.
- FixitMike
Yes, that is the way to do it in VCarve, too. I blame my keyboard dyslexia.Dale Yeager wrote:Thanks guys, work great with one change. In Cut 2D, after selecting both the box and text, I had to use pocket path, not profile.
- SteveNelson46
Do you mean "lesdyxia"?FixitMike wrote:Yes, that is the way to do it in VCarve, too. I blame my keyboard dyslexia.Dale Yeager wrote:Thanks guys, work great with one change. In Cut 2D, after selecting both the box and text, I had to use pocket path, not profile.
