HELP!!! for a new user
- Model of CNC Machine: Chinese 3040
Hi Folks
I am hoping someone can help me out. I have attached a .crv file that I have been working o. When I generate toolpaths it totally misses some of the internal pockets
I have wasted too many hours trying to figure it out so if someone can enlighten me I will be very grateful
I have uploaded teh file pentacle2.crv
Regards
Colin
Regards
Colin
- pentacle2.crv
- (13.5 KiB) Downloaded 220 times
Re: HELP!!! for a new user
Not exactly sure what you what the end result to look like but you need to sort out the crossing vectors in the star if you want that to be solid. You only need the outline not the internal parts if that is the case. Also you should weld the tips to the circle if you want it to be connected. The pocket toolpath really hates overlapping vectors.
Hi Adrian, Thanks for the reply.
What I am looking to achieve is an outer circle with all but the lines between the 2 stars pocketed out inside the circle
Cheers
Colin
Cheers
Colin
- mezalick
Colin,
Is this what you're looking for??
Michael
Michael
- pentacle2_1.crv
- (237.5 KiB) Downloaded 196 times
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
Like the attached image? If so you need to do what I suggest in my previous post as that is the result of that.
OK, I should not do stuff on no sleep for 28 hours
I have attached the correct .crv file.
What I am trying to achieve is the circle with the pentacle inside it raised and with all 5 sides of the pentacle complete
Thank you for your assistance
Cheers
Colin
Cheers
Colin
- pentacle3.crv
- (205.5 KiB) Downloaded 185 times
Please excuse my bad freehand photoediting but this gives an indication of my desired final result
Cheers
Colin
Cheers
Colin
The attached file should do what you want. You needed to use the trim tool (scissors) to modify the star to get rid of the overlapping vectors.
- pentacle3.crv
- (203 KiB) Downloaded 173 times
- mezalick
Try this...
Michael
Michael
- pentacle3_1.crv
- (402 KiB) Downloaded 189 times
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
- mezalick
Adrian wrote:The attached file should do what you want. You needed to use the trim tool (scissors) to modify the star to get rid of the overlapping vectors.
Just too quick for me Adrian......
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
Thank You very much for your help. I knew it would be something simple that I was overlooking
All the very best
Colin
All the very best
Colin
