new user
- Model of CNC Machine: Cnc shark pro
new user
still trying to learn where can i learn to curve text on cut 2 D??????
- Model of CNC Machine: Shark HD
Re: new user
I don't know if this link still works.... but it would be worth a try.
http://support.vectric.com/tutorials/V8 ... cks_3.html
- Model of CNC Machine: Shark HD 2.0
Re: new user
Look on this page. You'll find what you're looking for under the Drawing and Layout Tools. There's a blue box and in it you'll see a curved line with letters above it. To put text on a curve simply draw your curve, use the Draw Text icon to type out the text. Then Highlight the text, (click on it), using the shift key, click on the the curve you drew. They should both be pink now. Once they are both highlighted, click the Text on a curve icon and a box will pop up where you can put the text on the curve, above it, or below it. You should size your text to fit on the curve before you do this, or the program could do it for you. Aspire does.
Rick
Shark HD 2.0
Shark HD 2.0
