Cutting a 3D image with the Piranha
- Model of CNC Machine: 141001
Ok, I'm still a noob, and will need lots of help. I bought some 3D images and want to start the carving but I can not bring up the tool paths to see what bits I need for the carving. I believe that I will need to buy a couple other programs to add to my growing supply. The questions I really have that need answers are which program(s) will allow me to see the tool paths of drawings that I purchased, scan drawings to save with correct file extensions, and let me draw in 3D. The programs that I have looked at are too expensive and are almost out of the question. With all of the programs out there I am confused as to which one(s) will provide me with what I need.
Re: Cutting a 3D image with the Piranha
Study the tutorials and follow along. There is a great amount of information there. http://support.vectric.com/training-material. We all been there, you have to look at the tutorials, also click on the help content in your program.
Tony
Tony
You have to provide the toolpaths
Tony
Tony
What type of 3D images are they? If you bought them from VectorArt3D then you can use the free Vector Art Machinist programs to create toolpaths that you can import into Cut2D.
This link - http://www.vectric.com/products/compare.html - will show you the capabilities of the Vectric programs. To do everything you're talking about you really need Aspire.
Alright, I will have to get a program that will look at the 3D images I bought from Vector Art 3D and enable me to make the toolpaths. Will the program Aspire provide me with what I need. I will be looking at the information helps provided by Vectric in the mean time. I'm looking for a definative answer here.
Which programs do you already own? You've posted in the Cut2D section so I was assuming you owned Cut2d. If you download the Vector Art Machinist program from Vector Art 3D (it's free) you can use that to make toolpaths you can import into Cut2D.
Otherwise you can machine purchased 3D art directly with Cut3D, VCarve or Aspire. Did you look at the link with the capabilities of the programs in my previous post? It's all down to what you're wanting to do at the end of the day.
If you want to create 3D from scratch using a Vectric program then you need Aspire.
Ok, I am going to haqve to save my money to buy Aspire. the other answers were provided by these replies. Thanks.
The 3D images were bought from Vector Art 3D.
- Ms Wolffie
You can use the programs that came with the Piranha.
It's just a matter of crawling before you can walk.
Study the tutorials first.
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
