Text reversed using Mach3
cnc novice
Model of CNC Machine: desktop cnc router
Post by cnc novice »
When I try to cut text using Mach3, it cuts backwards. Does anyone have this problem and how to fix it? :D
Mike-S
Re: Text reversed using Mach3
Post by Mike-S »
Try reversing X and Y settings in Ports and Pins:
ger21
Post by ger21 »
Is it backwards in the Mach3 toolpath window?
Stuart
Model of CNC Machine: SXCNC 6040
Post by Stuart »
Great News!! I also watched the other cnc functions perform and they were backward/reversed to. I went to the Mach3 side and was making the changes in Outputs when you got back with me. Made the changes and up and away. I won't be able to stand up for the next hour. Thank you!! - S
