y is off .120
- Model of CNC Machine: home built
y is off .120
I cut two ovals in cut 2d. 9.5 in the x and 6.5 in they. the y cut to 6.620. to check my machine I cut a 4 in circle and it is within .004. any idea what is going on ? Dan
- Mike-S
Re: y is off .120
Have you set "Steps per" in the Y axis?
Also, did the bit return to physical 0,0 (not DRO 0,0) after cutting the ovals?
Re: y is off .120
Mike.... I did set all axis with a dial indicator awhile back. i'll have to run another one to see if it returns to 0 . what is the issue if it doesn't? i'm new at this cnc stuff ...Dan
- Model of CNC Machine: Professional done home built.
Re: y is off .120
the issue,
If the cutter returns back exactly where it started,,, that eliminates a mechanical problem.
And shows there is a problem in the software side of the tackle.
If the cutter returns back and is offset from the exact starting position that shows a machine problem.
Re: y is off .120
good info Signman....i'll try cutting another and see...Dan
- dhellew2
Re: y is off .120
It is a good idea to reference your machine every time it has been turned off or set for awhile in case the power blipped. Setting the DRO without setting the machine first will cause erratic results
Dale
Dale
Young = time, no money
Old = money, no time
Dale
Dale
Re: y is off .120
ok I ran another oval and the tool came back to the same point as started.
what process do I use to find the error in the software? and remember to type slowly i'm new at this. Dan
Re: y is off .120
Are both the X and Y off by the same amount or is X perfect?
Does your machine use Gcode or some other control language? Can you examine the output from Cut2d to see if the error is there or the control program on your CNC?
Re: y is off .120
thanks Kstross..........x is right on but off in Y and yes it uses G code.
how do I go about examining the output from cut 2d? the only thing I can think to do is redraw the oval and see if there is a change?
I built this machine from scratch so anything is a possible culprit.... Dan
Re: y is off .120
Draw an ellipse centered at 0,0 with major and minor axis dimensions of 9.5 / 6.5 in Cut2D and define a path that cuts *on* the ellipse. Output the gcode to a file and look at it in Notepad or other text editor. You should see many move commands with their x values varying from -4.75 to +4.75 and their y values varying from -3.25 ti +3.25. If the generated gcode is wrong then there is a bug in cut2d but if the code is correct and cuts wrong then there is a problem with you machine and/or controller.
Alternatively, post your file here and others may be able to spot the problem.
Re: y is off .120
g code for oval
( ovel on the line )
( File created: Sunday June 14 2015 - 04:30 PM)
( for Mach2/3 from Vectric )
( Material Size)
( X= 10.000, Y= 10.000, Z= 0.250)
(Toolpaths used in this file:)
(Profile 1)
(Tools used in this file: )
(1 = End Mill {0.125 inches})
N100G00G20G17G90G40G49G80
N110G70G91.1
N120T1M06
N130 (Tool: End Mill {0.125 inches})
N140G00G43Z0.8000H1
N150S12000M03
N160(Toolpath:- Profile 1)
N170()
N180G94
N190X0.0000Y0.0000F100.0
N200G00X0.0000Y3.2500Z0.2000
N210G1X0.0000Y3.2500Z-0.0520F30.0
N220G1X0.1226Y3.2489Z-0.0520F100.0
N230G1X0.2444Y3.2458Z-0.0520
N240G1X0.3655Y3.2405Z-0.0520
N250G1X0.4857Y3.2332Z-0.0520
N260G1X0.6050Y3.2239Z-0.0520
N270G1X0.7234Y3.2126Z-0.0520
N280G1X0.8408Y3.1992Z-0.0520
N290G1X0.9573Y3.1840Z-0.0520
N300G1X1.0727Y3.1668Z-0.0520
N310G1X1.1871Y3.1477Z-0.0520
N320G1X1.3004Y3.1267Z-0.0520
N330G1X1.4125Y3.1039Z-0.0520
N340G1X1.5235Y3.0792Z-0.0520
N350G1X1.6332Y3.0528Z-0.0520
N360G1X1.7417Y3.0246Z-0.0520
N370G1X1.8489Y2.9946Z-0.0520
N380G1X1.9548Y2.9629Z-0.0520
N390G1X2.0593Y2.9295Z-0.0520
N400G1X2.1624Y2.8945Z-0.0520
N410G1X2.2641Y2.8577Z-0.0520
N420G1X2.3643Y2.8194Z-0.0520
N430G1X2.4630Y2.7795Z-0.0520
N440G1X2.5602Y2.7380Z-0.0520
N450G1X2.6558Y2.6950Z-0.0520
N460G1X2.7497Y2.6504Z-0.0520
N470G1X2.8420Y2.6043Z-0.0520
N480G1X2.9326Y2.5568Z-0.0520
N490G1X3.0214Y2.5079Z-0.0520
N500G1X3.1085Y2.4575Z-0.0520
N510G1X3.1938Y2.4057Z-0.0520
N520G1X3.2772Y2.3526Z-0.0520
N530G1X3.3588Y2.2981Z-0.0520
N540G1X3.4384Y2.2423Z-0.0520
N550G1X3.5160Y2.1852Z-0.0520
N560G1X3.5917Y2.1269Z-0.0520
N570G1X3.6653Y2.0673Z-0.0520
N580G1X3.7369Y2.0065Z-0.0520
N590G1X3.8063Y1.9445Z-0.0520
N600G1X3.8737Y1.8814Z-0.0520
N610G1X3.9388Y1.8171Z-0.0520
N620G1X3.9705Y1.7845Z-0.0520
N630G1X4.0017Y1.7517Z-0.0520
N640G1X4.0323Y1.7186Z-0.0520
N650G1X4.0623Y1.6852Z-0.0520
N660G1X4.0918Y1.6516Z-0.0520
N670G1X4.1207Y1.6177Z-0.0520
N680G1X4.1490Y1.5836Z-0.0520
N690G1X4.1767Y1.5491Z-0.0520
N700G1X4.2038Y1.5145Z-0.0520
N710G1X4.2304Y1.4796Z-0.0520
N720G1X4.2563Y1.4444Z-0.0520
N730G1X4.2816Y1.4090Z-0.0520
N740G1X4.3063Y1.3734Z-0.0520
N750G1X4.3304Y1.3375Z-0.0520
N760G1X4.3539Y1.3014Z-0.0520
N770G1X4.3767Y1.2650Z-0.0520
N780G1X4.3989Y1.2285Z-0.0520
N790G1X4.4205Y1.1917Z-0.0520
N800G1X4.4415Y1.1547Z-0.0520
N810G1X4.4618Y1.1175Z-0.0520
N820G1X4.4814Y1.0800Z-0.0520
N830G1X4.5004Y1.0424Z-0.0520
N840G1X4.5188Y1.0045Z-0.0520
N850G1X4.5364Y0.9665Z-0.0520
N860G1X4.5535Y0.9282Z-0.0520
N870G1X4.5698Y0.8897Z-0.0520
N880G1X4.5855Y0.8511Z-0.0520
N890G1X4.6005Y0.8122Z-0.0520
N900G1X4.6148Y0.7732Z-0.0520
N910G1X4.6284Y0.7340Z-0.0520
N920G1X4.6413Y0.6946Z-0.0520
N930G1X4.6535Y0.6550Z-0.0520
N940G1X4.6650Y0.6152Z-0.0520
N950G1X4.6758Y0.5753Z-0.0520
N960G1X4.6859Y0.5352Z-0.0520
N970G1X4.6953Y0.4949Z-0.0520
N980G1X4.7039Y0.4545Z-0.0520
N990G1X4.7118Y0.4139Z-0.0520
N1000G1X4.7190Y0.3732Z-0.0520
N1010G1X4.7255Y0.3323Z-0.0520
N1020G1X4.7312Y0.2912Z-0.0520
N1030G1X4.7361Y0.2501Z-0.0520
N1040G1X4.7404Y0.2087Z-0.0520
N1050G1X4.7438Y0.1672Z-0.0520
N1060G1X4.7465Y0.1256Z-0.0520
N1070G1X4.7484Y0.0839Z-0.0520
N1080G1X4.7496Y0.0420Z-0.0520
N1090G1X4.7500Y0.0000Z-0.0520
N1100G1X4.7496Y-0.0420Z-0.0520
N1110G1X4.7484Y-0.0839Z-0.0520
N1120G1X4.7465Y-0.1256Z-0.0520
N1130G1X4.7438Y-0.1672Z-0.0520
N1140G1X4.7404Y-0.2087Z-0.0520
N1150G1X4.7361Y-0.2501Z-0.0520
N1160G1X4.7312Y-0.2912Z-0.0520
N1170G1X4.7255Y-0.3323Z-0.0520
N1180G1X4.7190Y-0.3732Z-0.0520
N1190G1X4.7118Y-0.4139Z-0.0520
N1200G1X4.7039Y-0.4545Z-0.0520
N1210G1X4.6953Y-0.4949Z-0.0520
N1220G1X4.6859Y-0.5352Z-0.0520
N1230G1X4.6758Y-0.5753Z-0.0520
N1240G1X4.6650Y-0.6152Z-0.0520
N1250G1X4.6535Y-0.6550Z-0.0520
N1260G1X4.6413Y-0.6946Z-0.0520
N1270G1X4.6284Y-0.7340Z-0.0520
N1280G1X4.6148Y-0.7732Z-0.0520
N1290G1X4.6005Y-0.8122Z-0.0520
N1300G1X4.5855Y-0.8511Z-0.0520
N1310G1X4.5698Y-0.8897Z-0.0520
N1320G1X4.5535Y-0.9282Z-0.0520
N1330G1X4.5364Y-0.9665Z-0.0520
N1340G1X4.5188Y-1.0045Z-0.0520
N1350G1X4.5004Y-1.0424Z-0.0520
N1360G1X4.4814Y-1.0800Z-0.0520
N1370G1X4.4618Y-1.1175Z-0.0520
N1380G1X4.4415Y-1.1547Z-0.0520
N1390G1X4.4205Y-1.1917Z-0.0520
N1400G1X4.3989Y-1.2285Z-0.0520
N1410G1X4.3767Y-1.2650Z-0.0520
N1420G1X4.3539Y-1.3014Z-0.0520
N1430G1X4.3304Y-1.3375Z-0.0520
N1440G1X4.3063Y-1.3734Z-0.0520
N1450G1X4.2816Y-1.4090Z-0.0520
N1460G1X4.2563Y-1.4444Z-0.0520
N1470G1X4.2304Y-1.4796Z-0.0520
N1480G1X4.2038Y-1.5145Z-0.0520
N1490G1X4.1767Y-1.5491Z-0.0520
N1500G1X4.1490Y-1.5836Z-0.0520
N1510G1X4.1207Y-1.6177Z-0.0520
N1520G1X4.0918Y-1.6516Z-0.0520
N1530G1X4.0623Y-1.6852Z-0.0520
N1540G1X4.0323Y-1.7186Z-0.0520
N1550G1X4.0017Y-1.7517Z-0.0520
N1560G1X3.9705Y-1.7845Z-0.0520
N1570G1X3.9388Y-1.8171Z-0.0520
N1580G1X3.8737Y-1.8814Z-0.0520
N1590G1X3.8063Y-1.9445Z-0.0520
N1600G1X3.7369Y-2.0065Z-0.0520
N1610G1X3.6653Y-2.0673Z-0.0520
N1620G1X3.5917Y-2.1269Z-0.0520
N1630G1X3.5160Y-2.1852Z-0.0520
N1640G1X3.4384Y-2.2423Z-0.0520
N1650G1X3.3588Y-2.2981Z-0.0520
N1660G1X3.2772Y-2.3526Z-0.0520
N1670G1X3.1938Y-2.4057Z-0.0520
N1680G1X3.1085Y-2.4575Z-0.0520
N1690G1X3.0214Y-2.5079Z-0.0520
N1700G1X2.9326Y-2.5568Z-0.0520
N1710G1X2.8420Y-2.6043Z-0.0520
N1720G1X2.7497Y-2.6504Z-0.0520
N1730G1X2.6558Y-2.6950Z-0.0520
N1740G1X2.5602Y-2.7380Z-0.0520
N1750G1X2.4630Y-2.7795Z-0.0520
N1760G1X2.3643Y-2.8194Z-0.0520
N1770G1X2.2641Y-2.8577Z-0.0520
N1780G1X2.1624Y-2.8945Z-0.0520
N1790G1X2.0593Y-2.9295Z-0.0520
N1800G1X1.9548Y-2.9629Z-0.0520
N1810G1X1.8489Y-2.9946Z-0.0520
N1820G1X1.7417Y-3.0246Z-0.0520
N1830G1X1.6332Y-3.0528Z-0.0520
N1840G1X1.5235Y-3.0792Z-0.0520
N1850G1X1.4125Y-3.1039Z-0.0520
N1860G1X1.3004Y-3.1267Z-0.0520
N1870G1X1.1871Y-3.1477Z-0.0520
N1880G1X1.0727Y-3.1668Z-0.0520
N1890G1X0.9573Y-3.1840Z-0.0520
N1900G1X0.8408Y-3.1992Z-0.0520
N1910G1X0.7234Y-3.2126Z-0.0520
N1920G1X0.6050Y-3.2239Z-0.0520
N1930G1X0.4857Y-3.2332Z-0.0520
N1940G1X0.3655Y-3.2405Z-0.0520
N1950G1X0.2444Y-3.2458Z-0.0520
N1960G1X0.1226Y-3.2489Z-0.0520
N1970G1X0.0000Y-3.2500Z-0.0520
N1980G1X-0.1226Y-3.2489Z-0.0520
N1990G1X-0.2444Y-3.2458Z-0.0520
N2000G1X-0.3655Y-3.2405Z-0.0520
N2010G1X-0.4857Y-3.2332Z-0.0520
N2020G1X-0.6050Y-3.2239Z-0.0520
N2030G1X-0.7234Y-3.2126Z-0.0520
N2040G1X-0.8408Y-3.1992Z-0.0520
N2050G1X-0.9573Y-3.1840Z-0.0520
N2060G1X-1.0727Y-3.1668Z-0.0520
N2070G1X-1.1871Y-3.1477Z-0.0520
N2080G1X-1.3004Y-3.1267Z-0.0520
N2090G1X-1.4125Y-3.1039Z-0.0520
N2100G1X-1.5235Y-3.0792Z-0.0520
N2110G1X-1.6332Y-3.0528Z-0.0520
N2120G1X-1.7417Y-3.0246Z-0.0520
N2130G1X-1.8489Y-2.9946Z-0.0520
N2140G1X-1.9548Y-2.9629Z-0.0520
N2150G1X-2.0593Y-2.9295Z-0.0520
N2160G1X-2.1624Y-2.8945Z-0.0520
N2170G1X-2.2641Y-2.8577Z-0.0520
N2180G1X-2.3643Y-2.8194Z-0.0520
N2190G1X-2.4630Y-2.7795Z-0.0520
N2200G1X-2.5602Y-2.7380Z-0.0520
N2210G1X-2.6558Y-2.6950Z-0.0520
N2220G1X-2.7497Y-2.6504Z-0.0520
N2230G1X-2.8420Y-2.6043Z-0.0520
N2240G1X-2.9326Y-2.5568Z-0.0520
N2250G1X-3.0214Y-2.5079Z-0.0520
N2260G1X-3.1085Y-2.4575Z-0.0520
N2270G1X-3.1938Y-2.4057Z-0.0520
N2280G1X-3.2772Y-2.3526Z-0.0520
N2290G1X-3.3588Y-2.2981Z-0.0520
N2300G1X-3.4384Y-2.2423Z-0.0520
N2310G1X-3.5160Y-2.1852Z-0.0520
N2320G1X-3.5917Y-2.1269Z-0.0520
N2330G1X-3.6653Y-2.0673Z-0.0520
N2340G1X-3.7369Y-2.0065Z-0.0520
N2350G1X-3.8063Y-1.9445Z-0.0520
N2360G1X-3.8737Y-1.8814Z-0.0520
N2370G1X-3.9388Y-1.8171Z-0.0520
N2380G1X-3.9705Y-1.7845Z-0.0520
N2390G1X-4.0017Y-1.7517Z-0.0520
N2400G1X-4.0323Y-1.7186Z-0.0520
N2410G1X-4.0623Y-1.6852Z-0.0520
N2420G1X-4.0918Y-1.6516Z-0.0520
N2430G1X-4.1207Y-1.6177Z-0.0520
N2440G1X-4.1490Y-1.5836Z-0.0520
N2450G1X-4.1767Y-1.5491Z-0.0520
N2460G1X-4.2038Y-1.5145Z-0.0520
N2470G1X-4.2304Y-1.4796Z-0.0520
N2480G1X-4.2563Y-1.4444Z-0.0520
N2490G1X-4.2816Y-1.4090Z-0.0520
N2500G1X-4.3063Y-1.3734Z-0.0520
N2510G1X-4.3304Y-1.3375Z-0.0520
N2520G1X-4.3539Y-1.3014Z-0.0520
N2530G1X-4.3767Y-1.2650Z-0.0520
N2540G1X-4.3989Y-1.2285Z-0.0520
N2550G1X-4.4205Y-1.1917Z-0.0520
N2560G1X-4.4415Y-1.1547Z-0.0520
N2570G1X-4.4618Y-1.1175Z-0.0520
N2580G1X-4.4814Y-1.0800Z-0.0520
N2590G1X-4.5004Y-1.0424Z-0.0520
N2600G1X-4.5188Y-1.0045Z-0.0520
N2610G1X-4.5364Y-0.9665Z-0.0520
N2620G1X-4.5535Y-0.9282Z-0.0520
N2630G1X-4.5698Y-0.8897Z-0.0520
N2640G1X-4.5855Y-0.8511Z-0.0520
N2650G1X-4.6005Y-0.8122Z-0.0520
N2660G1X-4.6148Y-0.7732Z-0.0520
N2670G1X-4.6284Y-0.7340Z-0.0520
N2680G1X-4.6413Y-0.6946Z-0.0520
N2690G1X-4.6535Y-0.6550Z-0.0520
N2700G1X-4.6650Y-0.6152Z-0.0520
N2710G1X-4.6758Y-0.5753Z-0.0520
N2720G1X-4.6859Y-0.5352Z-0.0520
N2730G1X-4.6953Y-0.4949Z-0.0520
N2740G1X-4.7039Y-0.4545Z-0.0520
N2750G1X-4.7118Y-0.4139Z-0.0520
N2760G1X-4.7190Y-0.3732Z-0.0520
N2770G1X-4.7255Y-0.3323Z-0.0520
N2780G1X-4.7312Y-0.2912Z-0.0520
N2790G1X-4.7361Y-0.2501Z-0.0520
N2800G1X-4.7404Y-0.2087Z-0.0520
N2810G1X-4.7438Y-0.1672Z-0.0520
N2820G1X-4.7465Y-0.1256Z-0.0520
N2830G1X-4.7484Y-0.0839Z-0.0520
N2840G1X-4.7496Y-0.0420Z-0.0520
N2850G1X-4.7500Y0.0000Z-0.0520
N2860G1X-4.7496Y0.0420Z-0.0520
N2870G1X-4.7484Y0.0839Z-0.0520
N2880G1X-4.7465Y0.1256Z-0.0520
N2890G1X-4.7438Y0.1672Z-0.0520
N2900G1X-4.7404Y0.2087Z-0.0520
N2910G1X-4.7361Y0.2501Z-0.0520
N2920G1X-4.7312Y0.2912Z-0.0520
N2930G1X-4.7255Y0.3323Z-0.0520
N2940G1X-4.7190Y0.3732Z-0.0520
N2950G1X-4.7118Y0.4139Z-0.0520
N2960G1X-4.7039Y0.4545Z-0.0520
N2970G1X-4.6953Y0.4949Z-0.0520
N2980G1X-4.6859Y0.5352Z-0.0520
N2990G1X-4.6758Y0.5753Z-0.0520
N3000G1X-4.6650Y0.6152Z-0.0520
N3010G1X-4.6535Y0.6550Z-0.0520
N3020G1X-4.6413Y0.6946Z-0.0520
N3030G1X-4.6284Y0.7340Z-0.0520
N3040G1X-4.6148Y0.7732Z-0.0520
N3050G1X-4.6005Y0.8122Z-0.0520
N3060G1X-4.5855Y0.8511Z-0.0520
N3070G1X-4.5698Y0.8897Z-0.0520
N3080G1X-4.5535Y0.9282Z-0.0520
N3090G1X-4.5364Y0.9665Z-0.0520
N3100G1X-4.5188Y1.0045Z-0.0520
N3110G1X-4.5004Y1.0424Z-0.0520
N3120G1X-4.4814Y1.0800Z-0.0520
N3130G1X-4.4618Y1.1175Z-0.0520
N3140G1X-4.4415Y1.1547Z-0.0520
N3150G1X-4.4205Y1.1917Z-0.0520
N3160G1X-4.3989Y1.2285Z-0.0520
N3170G1X-4.3767Y1.2650Z-0.0520
N3180G1X-4.3539Y1.3014Z-0.0520
N3190G1X-4.3304Y1.3375Z-0.0520
N3200G1X-4.3063Y1.3734Z-0.0520
N3210G1X-4.2816Y1.4090Z-0.0520
N3220G1X-4.2563Y1.4444Z-0.0520
N3230G1X-4.2304Y1.4796Z-0.0520
N3240G1X-4.2038Y1.5145Z-0.0520
N3250G1X-4.1767Y1.5491Z-0.0520
N3260G1X-4.1490Y1.5836Z-0.0520
N3270G1X-4.1207Y1.6177Z-0.0520
N3280G1X-4.0918Y1.6516Z-0.0520
N3290G1X-4.0623Y1.6852Z-0.0520
N3300G1X-4.0323Y1.7186Z-0.0520
N3310G1X-4.0017Y1.7517Z-0.0520
N3320G1X-3.9705Y1.7845Z-0.0520
N3330G1X-3.9388Y1.8171Z-0.0520
N3340G1X-3.8737Y1.8814Z-0.0520
N3350G1X-3.8063Y1.9445Z-0.0520
N3360G1X-3.7369Y2.0065Z-0.0520
N3370G1X-3.6653Y2.0673Z-0.0520
N3380G1X-3.5917Y2.1269Z-0.0520
N3390G1X-3.5160Y2.1852Z-0.0520
N3400G1X-3.4384Y2.2423Z-0.0520
N3410G1X-3.3588Y2.2981Z-0.0520
N3420G1X-3.2772Y2.3526Z-0.0520
N3430G1X-3.1938Y2.4057Z-0.0520
N3440G1X-3.1085Y2.4575Z-0.0520
N3450G1X-3.0214Y2.5079Z-0.0520
N3460G1X-2.9326Y2.5568Z-0.0520
N3470G1X-2.8420Y2.6043Z-0.0520
N3480G1X-2.7497Y2.6504Z-0.0520
N3490G1X-2.6558Y2.6950Z-0.0520
N3500G1X-2.5602Y2.7380Z-0.0520
N3510G1X-2.4630Y2.7795Z-0.0520
N3520G1X-2.3643Y2.8194Z-0.0520
N3530G1X-2.2641Y2.8577Z-0.0520
N3540G1X-2.1624Y2.8945Z-0.0520
N3550G1X-2.0593Y2.9295Z-0.0520
N3560G1X-1.9548Y2.9629Z-0.0520
N3570G1X-1.8489Y2.9946Z-0.0520
N3580G1X-1.7417Y3.0246Z-0.0520
N3590G1X-1.6332Y3.0528Z-0.0520
N3600G1X-1.5235Y3.0792Z-0.0520
N3610G1X-1.4125Y3.1039Z-0.0520
N3620G1X-1.3004Y3.1267Z-0.0520
N3630G1X-1.1871Y3.1477Z-0.0520
N3640G1X-1.0727Y3.1668Z-0.0520
N3650G1X-0.9573Y3.1840Z-0.0520
N3660G1X-0.8408Y3.1992Z-0.0520
N3670G1X-0.7234Y3.2126Z-0.0520
N3680G1X-0.6050Y3.2239Z-0.0520
N3690G1X-0.4857Y3.2332Z-0.0520
N3700G1X-0.3655Y3.2405Z-0.0520
N3710G1X-0.2444Y3.2458Z-0.0520
N3720G1X-0.1226Y3.2489Z-0.0520
N3730G1X0.0000Y3.2500Z-0.0520
N3740G1X0.0000Y3.2500Z-0.1040F30.0
N3750G1X0.1226Y3.2489Z-0.1040F100.0
N3760G1X0.2444Y3.2458Z-0.1040
N3770G1X0.3655Y3.2405Z-0.1040
N3780G1X0.4857Y3.2332Z-0.1040
N3790G1X0.6050Y3.2239Z-0.1040
N3800G1X0.7234Y3.2126Z-0.1040
N3810G1X0.8408Y3.1992Z-0.1040
N3820G1X0.9573Y3.1840Z-0.1040
N3830G1X1.0727Y3.1668Z-0.1040
N3840G1X1.1871Y3.1477Z-0.1040
N3850G1X1.3004Y3.1267Z-0.1040
N3860G1X1.4125Y3.1039Z-0.1040
N3870G1X1.5235Y3.0792Z-0.1040
N3880G1X1.6332Y3.0528Z-0.1040
N3890G1X1.7417Y3.0246Z-0.1040
N3900G1X1.8489Y2.9946Z-0.1040
N3910G1X1.9548Y2.9629Z-0.1040
N3920G1X2.0593Y2.9295Z-0.1040
N3930G1X2.1624Y2.8945Z-0.1040
N3940G1X2.2641Y2.8577Z-0.1040
N3950G1X2.3643Y2.8194Z-0.1040
N3960G1X2.4630Y2.7795Z-0.1040
N3970G1X2.5602Y2.7380Z-0.1040
N3980G1X2.6558Y2.6950Z-0.1040
N3990G1X2.7497Y2.6504Z-0.1040
N4000G1X2.8420Y2.6043Z-0.1040
N4010G1X2.9326Y2.5568Z-0.1040
N4020G1X3.0214Y2.5079Z-0.1040
N4030G1X3.1085Y2.4575Z-0.1040
N4040G1X3.1938Y2.4057Z-0.1040
N4050G1X3.2772Y2.3526Z-0.1040
N4060G1X3.3588Y2.2981Z-0.1040
N4070G1X3.4384Y2.2423Z-0.1040
N4080G1X3.5160Y2.1852Z-0.1040
N4090G1X3.5917Y2.1269Z-0.1040
N4100G1X3.6653Y2.0673Z-0.1040
N4110G1X3.7369Y2.0065Z-0.1040
N4120G1X3.8063Y1.9445Z-0.1040
N4130G1X3.8737Y1.8814Z-0.1040
N4140G1X3.9388Y1.8171Z-0.1040
N4150G1X3.9705Y1.7845Z-0.1040
N4160G1X4.0017Y1.7517Z-0.1040
N4170G1X4.0323Y1.7186Z-0.1040
N4180G1X4.0623Y1.6852Z-0.1040
N4190G1X4.0918Y1.6516Z-0.1040
N4200G1X4.1207Y1.6177Z-0.1040
N4210G1X4.1490Y1.5836Z-0.1040
N4220G1X4.1767Y1.5491Z-0.1040
N4230G1X4.2038Y1.5145Z-0.1040
N4240G1X4.2304Y1.4796Z-0.1040
N4250G1X4.2563Y1.4444Z-0.1040
N4260G1X4.2816Y1.4090Z-0.1040
N4270G1X4.3063Y1.3734Z-0.1040
N4280G1X4.3304Y1.3375Z-0.1040
N4290G1X4.3539Y1.3014Z-0.1040
N4300G1X4.3767Y1.2650Z-0.1040
N4310G1X4.3989Y1.2285Z-0.1040
N4320G1X4.4205Y1.1917Z-0.1040
N4330G1X4.4415Y1.1547Z-0.1040
N4340G1X4.4618Y1.1175Z-0.1040
N4350G1X4.4814Y1.0800Z-0.1040
N4360G1X4.5004Y1.0424Z-0.1040
N4370G1X4.5188Y1.0045Z-0.1040
N4380G1X4.5364Y0.9665Z-0.1040
N4390G1X4.5535Y0.9282Z-0.1040
N4400G1X4.5698Y0.8897Z-0.1040
N4410G1X4.5855Y0.8511Z-0.1040
N4420G1X4.6005Y0.8122Z-0.1040
N4430G1X4.6148Y0.7732Z-0.1040
N4440G1X4.6284Y0.7340Z-0.1040
N4450G1X4.6413Y0.6946Z-0.1040
N4460G1X4.6535Y0.6550Z-0.1040
N4470G1X4.6650Y0.6152Z-0.1040
N4480G1X4.6758Y0.5753Z-0.1040
N4490G1X4.6859Y0.5352Z-0.1040
N4500G1X4.6953Y0.4949Z-0.1040
N4510G1X4.7039Y0.4545Z-0.1040
N4520G1X4.7118Y0.4139Z-0.1040
N4530G1X4.7190Y0.3732Z-0.1040
N4540G1X4.7255Y0.3323Z-0.1040
N4550G1X4.7312Y0.2912Z-0.1040
N4560G1X4.7361Y0.2501Z-0.1040
N4570G1X4.7404Y0.2087Z-0.1040
N4580G1X4.7438Y0.1672Z-0.1040
N4590G1X4.7465Y0.1256Z-0.1040
N4600G1X4.7484Y0.0839Z-0.1040
N4610G1X4.7496Y0.0420Z-0.1040
N4620G1X4.7500Y0.0000Z-0.1040
N4630G1X4.7496Y-0.0420Z-0.1040
N4640G1X4.7484Y-0.0839Z-0.1040
N4650G1X4.7465Y-0.1256Z-0.1040
N4660G1X4.7438Y-0.1672Z-0.1040
N4670G1X4.7404Y-0.2087Z-0.1040
N4680G1X4.7361Y-0.2501Z-0.1040
N4690G1X4.7312Y-0.2912Z-0.1040
N4700G1X4.7255Y-0.3323Z-0.1040
N4710G1X4.7190Y-0.3732Z-0.1040
N4720G1X4.7118Y-0.4139Z-0.1040
N4730G1X4.7039Y-0.4545Z-0.1040
N4740G1X4.6953Y-0.4949Z-0.1040
N4750G1X4.6859Y-0.5352Z-0.1040
N4760G1X4.6758Y-0.5753Z-0.1040
N4770G1X4.6650Y-0.6152Z-0.1040
N4780G1X4.6535Y-0.6550Z-0.1040
N4790G1X4.6413Y-0.6946Z-0.1040
N4800G1X4.6284Y-0.7340Z-0.1040
N4810G1X4.6148Y-0.7732Z-0.1040
N4820G1X4.6005Y-0.8122Z-0.1040
N4830G1X4.5855Y-0.8511Z-0.1040
N4840G1X4.5698Y-0.8897Z-0.1040
N4850G1X4.5535Y-0.9282Z-0.1040
N4860G1X4.5364Y-0.9665Z-0.1040
N4870G1X4.5188Y-1.0045Z-0.1040
N4880G1X4.5004Y-1.0424Z-0.1040
N4890G1X4.4814Y-1.0800Z-0.1040
N4900G1X4.4618Y-1.1175Z-0.1040
N4910G1X4.4415Y-1.1547Z-0.1040
N4920G1X4.4205Y-1.1917Z-0.1040
N4930G1X4.3989Y-1.2285Z-0.1040
N4940G1X4.3767Y-1.2650Z-0.1040
N4950G1X4.3539Y-1.3014Z-0.1040
N4960G1X4.3304Y-1.3375Z-0.1040
N4970G1X4.3063Y-1.3734Z-0.1040
N4980G1X4.2816Y-1.4090Z-0.1040
N4990G1X4.2563Y-1.4444Z-0.1040
N5000G1X4.2304Y-1.4796Z-0.1040
N5010G1X4.2038Y-1.5145Z-0.1040
N5020G1X4.1767Y-1.5491Z-0.1040
N5030G1X4.1490Y-1.5836Z-0.1040
N5040G1X4.1207Y-1.6177Z-0.1040
N5050G1X4.0918Y-1.6516Z-0.1040
N5060G1X4.0623Y-1.6852Z-0.1040
N5070G1X4.0323Y-1.7186Z-0.1040
N5080G1X4.0017Y-1.7517Z-0.1040
N5090G1X3.9705Y-1.7845Z-0.1040
N5100G1X3.9388Y-1.8171Z-0.1040
N5110G1X3.8737Y-1.8814Z-0.1040
N5120G1X3.8063Y-1.9445Z-0.1040
N5130G1X3.7369Y-2.0065Z-0.1040
N5140G1X3.6653Y-2.0673Z-0.1040
N5150G1X3.5917Y-2.1269Z-0.1040
N5160G1X3.5160Y-2.1852Z-0.1040
N5170G1X3.4384Y-2.2423Z-0.1040
N5180G1X3.3588Y-2.2981Z-0.1040
N5190G1X3.2772Y-2.3526Z-0.1040
N5200G1X3.1938Y-2.4057Z-0.1040
N5210G1X3.1085Y-2.4575Z-0.1040
N5220G1X3.0214Y-2.5079Z-0.1040
N5230G1X2.9326Y-2.5568Z-0.1040
N5240G1X2.8420Y-2.6043Z-0.1040
N5250G1X2.7497Y-2.6504Z-0.1040
N5260G1X2.6558Y-2.6950Z-0.1040
N5270G1X2.5602Y-2.7380Z-0.1040
N5280G1X2.4630Y-2.7795Z-0.1040
N5290G1X2.3643Y-2.8194Z-0.1040
N5300G1X2.2641Y-2.8577Z-0.1040
N5310G1X2.1624Y-2.8945Z-0.1040
N5320G1X2.0593Y-2.9295Z-0.1040
N5330G1X1.9548Y-2.9629Z-0.1040
N5340G1X1.8489Y-2.9946Z-0.1040
N5350G1X1.7417Y-3.0246Z-0.1040
N5360G1X1.6332Y-3.0528Z-0.1040
N5370G1X1.5235Y-3.0792Z-0.1040
N5380G1X1.4125Y-3.1039Z-0.1040
N5390G1X1.3004Y-3.1267Z-0.1040
N5400G1X1.1871Y-3.1477Z-0.1040
N5410G1X1.0727Y-3.1668Z-0.1040
N5420G1X0.9573Y-3.1840Z-0.1040
N5430G1X0.8408Y-3.1992Z-0.1040
N5440G1X0.7234Y-3.2126Z-0.1040
N5450G1X0.6050Y-3.2239Z-0.1040
N5460G1X0.4857Y-3.2332Z-0.1040
N5470G1X0.3655Y-3.2405Z-0.1040
N5480G1X0.2444Y-3.2458Z-0.1040
N5490G1X0.1226Y-3.2489Z-0.1040
N5500G1X0.0000Y-3.2500Z-0.1040
N5510G1X-0.1226Y-3.2489Z-0.1040
N5520G1X-0.2444Y-3.2458Z-0.1040
N5530G1X-0.3655Y-3.2405Z-0.1040
N5540G1X-0.4857Y-3.2332Z-0.1040
N5550G1X-0.6050Y-3.2239Z-0.1040
N5560G1X-0.7234Y-3.2126Z-0.1040
N5570G1X-0.8408Y-3.1992Z-0.1040
N5580G1X-0.9573Y-3.1840Z-0.1040
N5590G1X-1.0727Y-3.1668Z-0.1040
N5600G1X-1.1871Y-3.1477Z-0.1040
N5610G1X-1.3004Y-3.1267Z-0.1040
N5620G1X-1.4125Y-3.1039Z-0.1040
N5630G1X-1.5235Y-3.0792Z-0.1040
N5640G1X-1.6332Y-3.0528Z-0.1040
N5650G1X-1.7417Y-3.0246Z-0.1040
N5660G1X-1.8489Y-2.9946Z-0.1040
N5670G1X-1.9548Y-2.9629Z-0.1040
N5680G1X-2.0593Y-2.9295Z-0.1040
N5690G1X-2.1624Y-2.8945Z-0.1040
N5700G1X-2.2641Y-2.8577Z-0.1040
N5710G1X-2.3643Y-2.8194Z-0.1040
N5720G1X-2.4630Y-2.7795Z-0.1040
N5730G1X-2.5602Y-2.7380Z-0.1040
N5740G1X-2.6558Y-2.6950Z-0.1040
N5750G1X-2.7497Y-2.6504Z-0.1040
N5760G1X-2.8420Y-2.6043Z-0.1040
N5770G1X-2.9326Y-2.5568Z-0.1040
N5780G1X-3.0214Y-2.5079Z-0.1040
N5790G1X-3.1085Y-2.4575Z-0.1040
N5800G1X-3.1938Y-2.4057Z-0.1040
N5810G1X-3.2772Y-2.3526Z-0.1040
N5820G1X-3.3588Y-2.2981Z-0.1040
N5830G1X-3.4384Y-2.2423Z-0.1040
N5840G1X-3.5160Y-2.1852Z-0.1040
N5850G1X-3.5917Y-2.1269Z-0.1040
N5860G1X-3.6653Y-2.0673Z-0.1040
N5870G1X-3.7369Y-2.0065Z-0.1040
N5880G1X-3.8063Y-1.9445Z-0.1040
N5890G1X-3.8737Y-1.8814Z-0.1040
N5900G1X-3.9388Y-1.8171Z-0.1040
N5910G1X-3.9705Y-1.7845Z-0.1040
N5920G1X-4.0017Y-1.7517Z-0.1040
N5930G1X-4.0323Y-1.7186Z-0.1040
N5940G1X-4.0623Y-1.6852Z-0.1040
N5950G1X-4.0918Y-1.6516Z-0.1040
N5960G1X-4.1207Y-1.6177Z-0.1040
N5970G1X-4.1490Y-1.5836Z-0.1040
N5980G1X-4.1767Y-1.5491Z-0.1040
N5990G1X-4.2038Y-1.5145Z-0.1040
N6000G1X-4.2304Y-1.4796Z-0.1040
N6010G1X-4.2563Y-1.4444Z-0.1040
N6020G1X-4.2816Y-1.4090Z-0.1040
N6030G1X-4.3063Y-1.3734Z-0.1040
N6040G1X-4.3304Y-1.3375Z-0.1040
N6050G1X-4.3539Y-1.3014Z-0.1040
N6060G1X-4.3767Y-1.2650Z-0.1040
N6070G1X-4.3989Y-1.2285Z-0.1040
N6080G1X-4.4205Y-1.1917Z-0.1040
N6090G1X-4.4415Y-1.1547Z-0.1040
N6100G1X-4.4618Y-1.1175Z-0.1040
N6110G1X-4.4814Y-1.0800Z-0.1040
N6120G1X-4.5004Y-1.0424Z-0.1040
N6130G1X-4.5188Y-1.0045Z-0.1040
N6140G1X-4.5364Y-0.9665Z-0.1040
N6150G1X-4.5535Y-0.9282Z-0.1040
N6160G1X-4.5698Y-0.8897Z-0.1040
N6170G1X-4.5855Y-0.8511Z-0.1040
N6180G1X-4.6005Y-0.8122Z-0.1040
N6190G1X-4.6148Y-0.7732Z-0.1040
N6200G1X-4.6284Y-0.7340Z-0.1040
N6210G1X-4.6413Y-0.6946Z-0.1040
N6220G1X-4.6535Y-0.6550Z-0.1040
N6230G1X-4.6650Y-0.6152Z-0.1040
N6240G1X-4.6758Y-0.5753Z-0.1040
N6250G1X-4.6859Y-0.5352Z-0.1040
N6260G1X-4.6953Y-0.4949Z-0.1040
N6270G1X-4.7039Y-0.4545Z-0.1040
N6280G1X-4.7118Y-0.4139Z-0.1040
N6290G1X-4.7190Y-0.3732Z-0.1040
N6300G1X-4.7255Y-0.3323Z-0.1040
N6310G1X-4.7312Y-0.2912Z-0.1040
N6320G1X-4.7361Y-0.2501Z-0.1040
N6330G1X-4.7404Y-0.2087Z-0.1040
N6340G1X-4.7438Y-0.1672Z-0.1040
N6350G1X-4.7465Y-0.1256Z-0.1040
N6360G1X-4.7484Y-0.0839Z-0.1040
N6370G1X-4.7496Y-0.0420Z-0.1040
N6380G1X-4.7500Y0.0000Z-0.1040
N6390G1X-4.7496Y0.0420Z-0.1040
N6400G1X-4.7484Y0.0839Z-0.1040
N6410G1X-4.7465Y0.1256Z-0.1040
N6420G1X-4.7438Y0.1672Z-0.1040
N6430G1X-4.7404Y0.2087Z-0.1040
N6440G1X-4.7361Y0.2501Z-0.1040
N6450G1X-4.7312Y0.2912Z-0.1040
N6460G1X-4.7255Y0.3323Z-0.1040
N6470G1X-4.7190Y0.3732Z-0.1040
N6480G1X-4.7118Y0.4139Z-0.1040
N6490G1X-4.7039Y0.4545Z-0.1040
N6500G1X-4.6953Y0.4949Z-0.1040
N6510G1X-4.6859Y0.5352Z-0.1040
N6520G1X-4.6758Y0.5753Z-0.1040
N6530G1X-4.6650Y0.6152Z-0.1040
N6540G1X-4.6535Y0.6550Z-0.1040
N6550G1X-4.6413Y0.6946Z-0.1040
N6560G1X-4.6284Y0.7340Z-0.1040
N6570G1X-4.6148Y0.7732Z-0.1040
N6580G1X-4.6005Y0.8122Z-0.1040
N6590G1X-4.5855Y0.8511Z-0.1040
N6600G1X-4.5698Y0.8897Z-0.1040
N6610G1X-4.5535Y0.9282Z-0.1040
N6620G1X-4.5364Y0.9665Z-0.1040
N6630G1X-4.5188Y1.0045Z-0.1040
N6640G1X-4.5004Y1.0424Z-0.1040
N6650G1X-4.4814Y1.0800Z-0.1040
N6660G1X-4.4618Y1.1175Z-0.1040
N6670G1X-4.4415Y1.1547Z-0.1040
N6680G1X-4.4205Y1.1917Z-0.1040
N6690G1X-4.3989Y1.2285Z-0.1040
N6700G1X-4.3767Y1.2650Z-0.1040
N6710G1X-4.3539Y1.3014Z-0.1040
N6720G1X-4.3304Y1.3375Z-0.1040
N6730G1X-4.3063Y1.3734Z-0.1040
N6740G1X-4.2816Y1.4090Z-0.1040
N6750G1X-4.2563Y1.4444Z-0.1040
N6760G1X-4.2304Y1.4796Z-0.1040
N6770G1X-4.2038Y1.5145Z-0.1040
N6780G1X-4.1767Y1.5491Z-0.1040
N6790G1X-4.1490Y1.5836Z-0.1040
N6800G1X-4.1207Y1.6177Z-0.1040
N6810G1X-4.0918Y1.6516Z-0.1040
N6820G1X-4.0623Y1.6852Z-0.1040
N6830G1X-4.0323Y1.7186Z-0.1040
N6840G1X-4.0017Y1.7517Z-0.1040
N6850G1X-3.9705Y1.7845Z-0.1040
N6860G1X-3.9388Y1.8171Z-0.1040
N6870G1X-3.8737Y1.8814Z-0.1040
N6880G1X-3.8063Y1.9445Z-0.1040
N6890G1X-3.7369Y2.0065Z-0.1040
N6900G1X-3.6653Y2.0673Z-0.1040
N6910G1X-3.5917Y2.1269Z-0.1040
N6920G1X-3.5160Y2.1852Z-0.1040
N6930G1X-3.4384Y2.2423Z-0.1040
N6940G1X-3.3588Y2.2981Z-0.1040
N6950G1X-3.2772Y2.3526Z-0.1040
N6960G1X-3.1938Y2.4057Z-0.1040
N6970G1X-3.1085Y2.4575Z-0.1040
N6980G1X-3.0214Y2.5079Z-0.1040
N6990G1X-2.9326Y2.5568Z-0.1040
N7000G1X-2.8420Y2.6043Z-0.1040
N7010G1X-2.7497Y2.6504Z-0.1040
N7020G1X-2.6558Y2.6950Z-0.1040
N7030G1X-2.5602Y2.7380Z-0.1040
N7040G1X-2.4630Y2.7795Z-0.1040
N7050G1X-2.3643Y2.8194Z-0.1040
N7060G1X-2.2641Y2.8577Z-0.1040
N7070G1X-2.1624Y2.8945Z-0.1040
N7080G1X-2.0593Y2.9295Z-0.1040
N7090G1X-1.9548Y2.9629Z-0.1040
N7100G1X-1.8489Y2.9946Z-0.1040
N7110G1X-1.7417Y3.0246Z-0.1040
N7120G1X-1.6332Y3.0528Z-0.1040
N7130G1X-1.5235Y3.0792Z-0.1040
N7140G1X-1.4125Y3.1039Z-0.1040
N7150G1X-1.3004Y3.1267Z-0.1040
N7160G1X-1.1871Y3.1477Z-0.1040
N7170G1X-1.0727Y3.1668Z-0.1040
N7180G1X-0.9573Y3.1840Z-0.1040
N7190G1X-0.8408Y3.1992Z-0.1040
N7200G1X-0.7234Y3.2126Z-0.1040
N7210G1X-0.6050Y3.2239Z-0.1040
N7220G1X-0.4857Y3.2332Z-0.1040
N7230G1X-0.3655Y3.2405Z-0.1040
N7240G1X-0.2444Y3.2458Z-0.1040
N7250G1X-0.1226Y3.2489Z-0.1040
N7260G1X0.0000Y3.2500Z-0.1040
N7270G1X0.0000Y3.2500Z-0.1560F30.0
N7280G1X0.1226Y3.2489Z-0.1560F100.0
N7290G1X0.2444Y3.2458Z-0.1560
N7300G1X0.3655Y3.2405Z-0.1560
N7310G1X0.4857Y3.2332Z-0.1560
N7320G1X0.6050Y3.2239Z-0.1560
N7330G1X0.7234Y3.2126Z-0.1560
N7340G1X0.8408Y3.1992Z-0.1560
N7350G1X0.9573Y3.1840Z-0.1560
N7360G1X1.0727Y3.1668Z-0.1560
N7370G1X1.1871Y3.1477Z-0.1560
N7380G1X1.3004Y3.1267Z-0.1560
N7390G1X1.4125Y3.1039Z-0.1560
N7400G1X1.5235Y3.0792Z-0.1560
N7410G1X1.6332Y3.0528Z-0.1560
N7420G1X1.7417Y3.0246Z-0.1560
N7430G1X1.8489Y2.9946Z-0.1560
N7440G1X1.9548Y2.9629Z-0.1560
N7450G1X2.0593Y2.9295Z-0.1560
N7460G1X2.1624Y2.8945Z-0.1560
N7470G1X2.2641Y2.8577Z-0.1560
N7480G1X2.3643Y2.8194Z-0.1560
N7490G1X2.4630Y2.7795Z-0.1560
N7500G1X2.5602Y2.7380Z-0.1560
N7510G1X2.6558Y2.6950Z-0.1560
N7520G1X2.7497Y2.6504Z-0.1560
N7530G1X2.8420Y2.6043Z-0.1560
N7540G1X2.9326Y2.5568Z-0.1560
N7550G1X3.0214Y2.5079Z-0.1560
N7560G1X3.1085Y2.4575Z-0.1560
N7570G1X3.1938Y2.4057Z-0.1560
N7580G1X3.2772Y2.3526Z-0.1560
N7590G1X3.3588Y2.2981Z-0.1560
N7600G1X3.4384Y2.2423Z-0.1560
N7610G1X3.5160Y2.1852Z-0.1560
N7620G1X3.5917Y2.1269Z-0.1560
N7630G1X3.6653Y2.0673Z-0.1560
N7640G1X3.7369Y2.0065Z-0.1560
N7650G1X3.8063Y1.9445Z-0.1560
N7660G1X3.8737Y1.8814Z-0.1560
N7670G1X3.9388Y1.8171Z-0.1560
N7680G1X3.9705Y1.7845Z-0.1560
N7690G1X4.0017Y1.7517Z-0.1560
N7700G1X4.0323Y1.7186Z-0.1560
N7710G1X4.0623Y1.6852Z-0.1560
N7720G1X4.0918Y1.6516Z-0.1560
N7730G1X4.1207Y1.6177Z-0.1560
N7740G1X4.1490Y1.5836Z-0.1560
N7750G1X4.1767Y1.5491Z-0.1560
N7760G1X4.2038Y1.5145Z-0.1560
N7770G1X4.2304Y1.4796Z-0.1560
N7780G1X4.2563Y1.4444Z-0.1560
N7790G1X4.2816Y1.4090Z-0.1560
N7800G1X4.3063Y1.3734Z-0.1560
N7810G1X4.3304Y1.3375Z-0.1560
N7820G1X4.3539Y1.3014Z-0.1560
N7830G1X4.3767Y1.2650Z-0.1560
N7840G1X4.3989Y1.2285Z-0.1560
N7850G1X4.4205Y1.1917Z-0.1560
N7860G1X4.4415Y1.1547Z-0.1560
N7870G1X4.4618Y1.1175Z-0.1560
N7880G1X4.4814Y1.0800Z-0.1560
N7890G1X4.5004Y1.0424Z-0.1560
N7900G1X4.5188Y1.0045Z-0.1560
N7910G1X4.5364Y0.9665Z-0.1560
N7920G1X4.5535Y0.9282Z-0.1560
N7930G1X4.5698Y0.8897Z-0.1560
N7940G1X4.5855Y0.8511Z-0.1560
N7950G1X4.6005Y0.8122Z-0.1560
N7960G1X4.6148Y0.7732Z-0.1560
N7970G1X4.6284Y0.7340Z-0.1560
N7980G1X4.6413Y0.6946Z-0.1560
N7990G1X4.6535Y0.6550Z-0.1560
N8000G1X4.6650Y0.6152Z-0.1560
N8010G1X4.6758Y0.5753Z-0.1560
N8020G1X4.6859Y0.5352Z-0.1560
N8030G1X4.6953Y0.4949Z-0.1560
N8040G1X4.7039Y0.4545Z-0.1560
N8050G1X4.7118Y0.4139Z-0.1560
N8060G1X4.7190Y0.3732Z-0.1560
N8070G1X4.7255Y0.3323Z-0.1560
N8080G1X4.7312Y0.2912Z-0.1560
N8090G1X4.7361Y0.2501Z-0.1560
N8100G1X4.7404Y0.2087Z-0.1560
N8110G1X4.7438Y0.1672Z-0.1560
N8120G1X4.7465Y0.1256Z-0.1560
N8130G1X4.7484Y0.0839Z-0.1560
N8140G1X4.7496Y0.0420Z-0.1560
N8150G1X4.7500Y0.0000Z-0.1560
N8160G1X4.7496Y-0.0420Z-0.1560
N8170G1X4.7484Y-0.0839Z-0.1560
N8180G1X4.7465Y-0.1256Z-0.1560
N8190G1X4.7438Y-0.1672Z-0.1560
N8200G1X4.7404Y-0.2087Z-0.1560
N8210G1X4.7361Y-0.2501Z-0.1560
N8220G1X4.7312Y-0.2912Z-0.1560
N8230G1X4.7255Y-0.3323Z-0.1560
N8240G1X4.7190Y-0.3732Z-0.1560
N8250G1X4.7118Y-0.4139Z-0.1560
N8260G1X4.7039Y-0.4545Z-0.1560
N8270G1X4.6953Y-0.4949Z-0.1560
N8280G1X4.6859Y-0.5352Z-0.1560
N8290G1X4.6758Y-0.5753Z-0.1560
N8300G1X4.6650Y-0.6152Z-0.1560
N8310G1X4.6535Y-0.6550Z-0.1560
N8320G1X4.6413Y-0.6946Z-0.1560
N8330G1X4.6284Y-0.7340Z-0.1560
N8340G1X4.6148Y-0.7732Z-0.1560
N8350G1X4.6005Y-0.8122Z-0.1560
N8360G1X4.5855Y-0.8511Z-0.1560
N8370G1X4.5698Y-0.8897Z-0.1560
N8380G1X4.5535Y-0.9282Z-0.1560
N8390G1X4.5364Y-0.9665Z-0.1560
N8400G1X4.5188Y-1.0045Z-0.1560
N8410G1X4.5004Y-1.0424Z-0.1560
N8420G1X4.4814Y-1.0800Z-0.1560
N8430G1X4.4618Y-1.1175Z-0.1560
N8440G1X4.4415Y-1.1547Z-0.1560
N8450G1X4.4205Y-1.1917Z-0.1560
N8460G1X4.3989Y-1.2285Z-0.1560
N8470G1X4.3767Y-1.2650Z-0.1560
N8480G1X4.3539Y-1.3014Z-0.1560
N8490G1X4.3304Y-1.3375Z-0.1560
N8500G1X4.3063Y-1.3734Z-0.1560
N8510G1X4.2816Y-1.4090Z-0.1560
N8520G1X4.2563Y-1.4444Z-0.1560
N8530G1X4.2304Y-1.4796Z-0.1560
N8540G1X4.2038Y-1.5145Z-0.1560
N8550G1X4.1767Y-1.5491Z-0.1560
N8560G1X4.1490Y-1.5836Z-0.1560
N8570G1X4.1207Y-1.6177Z-0.1560
N8580G1X4.0918Y-1.6516Z-0.1560
N8590G1X4.0623Y-1.6852Z-0.1560
N8600G1X4.0323Y-1.7186Z-0.1560
N8610G1X4.0017Y-1.7517Z-0.1560
N8620G1X3.9705Y-1.7845Z-0.1560
N8630G1X3.9388Y-1.8171Z-0.1560
N8640G1X3.8737Y-1.8814Z-0.1560
N8650G1X3.8063Y-1.9445Z-0.1560
N8660G1X3.7369Y-2.0065Z-0.1560
N8670G1X3.6653Y-2.0673Z-0.1560
N8680G1X3.5917Y-2.1269Z-0.1560
N8690G1X3.5160Y-2.1852Z-0.1560
N8700G1X3.4384Y-2.2423Z-0.1560
N8710G1X3.3588Y-2.2981Z-0.1560
N8720G1X3.2772Y-2.3526Z-0.1560
N8730G1X3.1938Y-2.4057Z-0.1560
N8740G1X3.1085Y-2.4575Z-0.1560
N8750G1X3.0214Y-2.5079Z-0.1560
N8760G1X2.9326Y-2.5568Z-0.1560
N8770G1X2.8420Y-2.6043Z-0.1560
N8780G1X2.7497Y-2.6504Z-0.1560
N8790G1X2.6558Y-2.6950Z-0.1560
N8800G1X2.5602Y-2.7380Z-0.1560
N8810G1X2.4630Y-2.7795Z-0.1560
N8820G1X2.3643Y-2.8194Z-0.1560
N8830G1X2.2641Y-2.8577Z-0.1560
N8840G1X2.1624Y-2.8945Z-0.1560
N8850G1X2.0593Y-2.9295Z-0.1560
N8860G1X1.9548Y-2.9629Z-0.1560
N8870G1X1.8489Y-2.9946Z-0.1560
N8880G1X1.7417Y-3.0246Z-0.1560
N8890G1X1.6332Y-3.0528Z-0.1560
N8900G1X1.5235Y-3.0792Z-0.1560
N8910G1X1.4125Y-3.1039Z-0.1560
N8920G1X1.3004Y-3.1267Z-0.1560
N8930G1X1.1871Y-3.1477Z-0.1560
N8940G1X1.0727Y-3.1668Z-0.1560
N8950G1X0.9573Y-3.1840Z-0.1560
N8960G1X0.8408Y-3.1992Z-0.1560
N8970G1X0.7234Y-3.2126Z-0.1560
N8980G1X0.6050Y-3.2239Z-0.1560
N8990G1X0.4857Y-3.2332Z-0.1560
N9000G1X0.3655Y-3.2405Z-0.1560
N9010G1X0.2444Y-3.2458Z-0.1560
N9020G1X0.1226Y-3.2489Z-0.1560
N9030G1X0.0000Y-3.2500Z-0.1560
N9040G1X-0.1226Y-3.2489Z-0.1560
N9050G1X-0.2444Y-3.2458Z-0.1560
N9060G1X-0.3655Y-3.2405Z-0.1560
N9070G1X-0.4857Y-3.2332Z-0.1560
N9080G1X-0.6050Y-3.2239Z-0.1560
N9090G1X-0.7234Y-3.2126Z-0.1560
N9100G1X-0.8408Y-3.1992Z-0.1560
N9110G1X-0.9573Y-3.1840Z-0.1560
N9120G1X-1.0727Y-3.1668Z-0.1560
N9130G1X-1.1871Y-3.1477Z-0.1560
N9140G1X-1.3004Y-3.1267Z-0.1560
N9150G1X-1.4125Y-3.1039Z-0.1560
N9160G1X-1.5235Y-3.0792Z-0.1560
N9170G1X-1.6332Y-3.0528Z-0.1560
N9180G1X-1.7417Y-3.0246Z-0.1560
N9190G1X-1.8489Y-2.9946Z-0.1560
N9200G1X-1.9548Y-2.9629Z-0.1560
N9210G1X-2.0593Y-2.9295Z-0.1560
N9220G1X-2.1624Y-2.8945Z-0.1560
N9230G1X-2.2641Y-2.8577Z-0.1560
N9240G1X-2.3643Y-2.8194Z-0.1560
N9250G1X-2.4630Y-2.7795Z-0.1560
N9260G1X-2.5602Y-2.7380Z-0.1560
N9270G1X-2.6558Y-2.6950Z-0.1560
N9280G1X-2.7497Y-2.6504Z-0.1560
N9290G1X-2.8420Y-2.6043Z-0.1560
N9300G1X-2.9326Y-2.5568Z-0.1560
N9310G1X-3.0214Y-2.5079Z-0.1560
N9320G1X-3.1085Y-2.4575Z-0.1560
N9330G1X-3.1938Y-2.4057Z-0.1560
N9340G1X-3.2772Y-2.3526Z-0.1560
N9350G1X-3.3588Y-2.2981Z-0.1560
N9360G1X-3.4384Y-2.2423Z-0.1560
N9370G1X-3.5160Y-2.1852Z-0.1560
N9380G1X-3.5917Y-2.1269Z-0.1560
N9390G1X-3.6653Y-2.0673Z-0.1560
N9400G1X-3.7369Y-2.0065Z-0.1560
N9410G1X-3.8063Y-1.9445Z-0.1560
N9420G1X-3.8737Y-1.8814Z-0.1560
N9430G1X-3.9388Y-1.8171Z-0.1560
N9440G1X-3.9705Y-1.7845Z-0.1560
N9450G1X-4.0017Y-1.7517Z-0.1560
N9460G1X-4.0323Y-1.7186Z-0.1560
N9470G1X-4.0623Y-1.6852Z-0.1560
N9480G1X-4.0918Y-1.6516Z-0.1560
N9490G1X-4.1207Y-1.6177Z-0.1560
N9500G1X-4.1490Y-1.5836Z-0.1560
N9510G1X-4.1767Y-1.5491Z-0.1560
N9520G1X-4.2038Y-1.5145Z-0.1560
N9530G1X-4.2304Y-1.4796Z-0.1560
N9540G1X-4.2563Y-1.4444Z-0.1560
N9550G1X-4.2816Y-1.4090Z-0.1560
N9560G1X-4.3063Y-1.3734Z-0.1560
N9570G1X-4.3304Y-1.3375Z-0.1560
N9580G1X-4.3539Y-1.3014Z-0.1560
N9590G1X-4.3767Y-1.2650Z-0.1560
N9600G1X-4.3989Y-1.2285Z-0.1560
N9610G1X-4.4205Y-1.1917Z-0.1560
N9620G1X-4.4415Y-1.1547Z-0.1560
N9630G1X-4.4618Y-1.1175Z-0.1560
N9640G1X-4.4814Y-1.0800Z-0.1560
N9650G1X-4.5004Y-1.0424Z-0.1560
N9660G1X-4.5188Y-1.0045Z-0.1560
N9670G1X-4.5364Y-0.9665Z-0.1560
N9680G1X-4.5535Y-0.9282Z-0.1560
N9690G1X-4.5698Y-0.8897Z-0.1560
N9700G1X-4.5855Y-0.8511Z-0.1560
N9710G1X-4.6005Y-0.8122Z-0.1560
N9720G1X-4.6148Y-0.7732Z-0.1560
N9730G1X-4.6284Y-0.7340Z-0.1560
N9740G1X-4.6413Y-0.6946Z-0.1560
N9750G1X-4.6535Y-0.6550Z-0.1560
N9760G1X-4.6650Y-0.6152Z-0.1560
N9770G1X-4.6758Y-0.5753Z-0.1560
N9780G1X-4.6859Y-0.5352Z-0.1560
N9790G1X-4.6953Y-0.4949Z-0.1560
N9800G1X-4.7039Y-0.4545Z-0.1560
N9810G1X-4.7118Y-0.4139Z-0.1560
N9820G1X-4.7190Y-0.3732Z-0.1560
N9830G1X-4.7255Y-0.3323Z-0.1560
N9840G1X-4.7312Y-0.2912Z-0.1560
N9850G1X-4.7361Y-0.2501Z-0.1560
N9860G1X-4.7404Y-0.2087Z-0.1560
N9870G1X-4.7438Y-0.1672Z-0.1560
N9880G1X-4.7465Y-0.1256Z-0.1560
N9890G1X-4.7484Y-0.0839Z-0.1560
N9900G1X-4.7496Y-0.0420Z-0.1560
N9910G1X-4.7500Y0.0000Z-0.1560
N9920G1X-4.7496Y0.0420Z-0.1560
N9930G1X-4.7484Y0.0839Z-0.1560
N9940G1X-4.7465Y0.1256Z-0.1560
N9950G1X-4.7438Y0.1672Z-0.1560
N9960G1X-4.7404Y0.2087Z-0.1560
N9970G1X-4.7361Y0.2501Z-0.1560
N9980G1X-4.7312Y0.2912Z-0.1560
N9990G1X-4.7255Y0.3323Z-0.1560
N10000G1X-4.7190Y0.3732Z-0.1560
N10010G1X-4.7118Y0.4139Z-0.1560
N10020G1X-4.7039Y0.4545Z-0.1560
N10030G1X-4.6953Y0.4949Z-0.1560
N10040G1X-4.6859Y0.5352Z-0.1560
N10050G1X-4.6758Y0.5753Z-0.1560
N10060G1X-4.6650Y0.6152Z-0.1560
N10070G1X-4.6535Y0.6550Z-0.1560
N10080G1X-4.6413Y0.6946Z-0.1560
N10090G1X-4.6284Y0.7340Z-0.1560
N10100G1X-4.6148Y0.7732Z-0.1560
N10110G1X-4.6005Y0.8122Z-0.1560
N10120G1X-4.5855Y0.8511Z-0.1560
N10130G1X-4.5698Y0.8897Z-0.1560
N10140G1X-4.5535Y0.9282Z-0.1560
N10150G1X-4.5364Y0.9665Z-0.1560
N10160G1X-4.5188Y1.0045Z-0.1560
N10170G1X-4.5004Y1.0424Z-0.1560
N10180G1X-4.4814Y1.0800Z-0.1560
N10190G1X-4.4618Y1.1175Z-0.1560
N10200G1X-4.4415Y1.1547Z-0.1560
N10210G1X-4.4205Y1.1917Z-0.1560
N10220G1X-4.3989Y1.2285Z-0.1560
N10230G1X-4.3767Y1.2650Z-0.1560
N10240G1X-4.3539Y1.3014Z-0.1560
N10250G1X-4.3304Y1.3375Z-0.1560
N10260G1X-4.3063Y1.3734Z-0.1560
N10270G1X-4.2816Y1.4090Z-0.1560
N10280G1X-4.2563Y1.4444Z-0.1560
N10290G1X-4.2304Y1.4796Z-0.1560
N10300G1X-4.2038Y1.5145Z-0.1560
N10310G1X-4.1767Y1.5491Z-0.1560
N10320G1X-4.1490Y1.5836Z-0.1560
N10330G1X-4.1207Y1.6177Z-0.1560
N10340G1X-4.0918Y1.6516Z-0.1560
N10350G1X-4.0623Y1.6852Z-0.1560
N10360G1X-4.0323Y1.7186Z-0.1560
N10370G1X-4.0017Y1.7517Z-0.1560
N10380G1X-3.9705Y1.7845Z-0.1560
N10390G1X-3.9388Y1.8171Z-0.1560
N10400G1X-3.8737Y1.8814Z-0.1560
N10410G1X-3.8063Y1.9445Z-0.1560
N10420G1X-3.7369Y2.0065Z-0.1560
N10430G1X-3.6653Y2.0673Z-0.1560
N10440G1X-3.5917Y2.1269Z-0.1560
N10450G1X-3.5160Y2.1852Z-0.1560
N10460G1X-3.4384Y2.2423Z-0.1560
N10470G1X-3.3588Y2.2981Z-0.1560
N10480G1X-3.2772Y2.3526Z-0.1560
N10490G1X-3.1938Y2.4057Z-0.1560
N10500G1X-3.1085Y2.4575Z-0.1560
N10510G1X-3.0214Y2.5079Z-0.1560
N10520G1X-2.9326Y2.5568Z-0.1560
N10530G1X-2.8420Y2.6043Z-0.1560
N10540G1X-2.7497Y2.6504Z-0.1560
N10550G1X-2.6558Y2.6950Z-0.1560
N10560G1X-2.5602Y2.7380Z-0.1560
N10570G1X-2.4630Y2.7795Z-0.1560
N10580G1X-2.3643Y2.8194Z-0.1560
N10590G1X-2.2641Y2.8577Z-0.1560
N10600G1X-2.1624Y2.8945Z-0.1560
N10610G1X-2.0593Y2.9295Z-0.1560
N10620G1X-1.9548Y2.9629Z-0.1560
N10630G1X-1.8489Y2.9946Z-0.1560
N10640G1X-1.7417Y3.0246Z-0.1560
N10650G1X-1.6332Y3.0528Z-0.1560
N10660G1X-1.5235Y3.0792Z-0.1560
N10670G1X-1.4125Y3.1039Z-0.1560
N10680G1X-1.3004Y3.1267Z-0.1560
N10690G1X-1.1871Y3.1477Z-0.1560
N10700G1X-1.0727Y3.1668Z-0.1560
N10710G1X-0.9573Y3.1840Z-0.1560
N10720G1X-0.8408Y3.1992Z-0.1560
N10730G1X-0.7234Y3.2126Z-0.1560
N10740G1X-0.6050Y3.2239Z-0.1560
N10750G1X-0.4857Y3.2332Z-0.1560
N10760G1X-0.3655Y3.2405Z-0.1560
N10770G1X-0.2444Y3.2458Z-0.1560
N10780G1X-0.1226Y3.2489Z-0.1560
N10790G1X0.0000Y3.2500Z-0.1560
N10800G1X0.0000Y3.2500Z-0.2080F30.0
N10810G1X0.1226Y3.2489Z-0.2080F100.0
N10820G1X0.2444Y3.2458Z-0.2080
N10830G1X0.3655Y3.2405Z-0.2080
N10840G1X0.4857Y3.2332Z-0.2080
N10850G1X0.6050Y3.2239Z-0.2080
N10860G1X0.7234Y3.2126Z-0.2080
N10870G1X0.8408Y3.1992Z-0.2080
N10880G1X0.9573Y3.1840Z-0.2080
N10890G1X1.0727Y3.1668Z-0.2080
N10900G1X1.1871Y3.1477Z-0.2080
N10910G1X1.3004Y3.1267Z-0.2080
N10920G1X1.4125Y3.1039Z-0.2080
N10930G1X1.5235Y3.0792Z-0.2080
N10940G1X1.6332Y3.0528Z-0.2080
N10950G1X1.7417Y3.0246Z-0.2080
N10960G1X1.8489Y2.9946Z-0.2080
N10970G1X1.9548Y2.9629Z-0.2080
N10980G1X2.0593Y2.9295Z-0.2080
N10990G1X2.1624Y2.8945Z-0.2080
N11000G1X2.2641Y2.8577Z-0.2080
N11010G1X2.3643Y2.8194Z-0.2080
N11020G1X2.4630Y2.7795Z-0.2080
N11030G1X2.5602Y2.7380Z-0.2080
N11040G1X2.6558Y2.6950Z-0.2080
N11050G1X2.7497Y2.6504Z-0.2080
N11060G1X2.8420Y2.6043Z-0.2080
N11070G1X2.9326Y2.5568Z-0.2080
N11080G1X3.0214Y2.5079Z-0.2080
N11090G1X3.1085Y2.4575Z-0.2080
N11100G1X3.1938Y2.4057Z-0.2080
N11110G1X3.2772Y2.3526Z-0.2080
N11120G1X3.3588Y2.2981Z-0.2080
N11130G1X3.4384Y2.2423Z-0.2080
N11140G1X3.5160Y2.1852Z-0.2080
N11150G1X3.5917Y2.1269Z-0.2080
N11160G1X3.6653Y2.0673Z-0.2080
N11170G1X3.7369Y2.0065Z-0.2080
N11180G1X3.8063Y1.9445Z-0.2080
N11190G1X3.8737Y1.8814Z-0.2080
N11200G1X3.9388Y1.8171Z-0.2080
N11210G1X3.9705Y1.7845Z-0.2080
N11220G1X4.0017Y1.7517Z-0.2080
N11230G1X4.0323Y1.7186Z-0.2080
N11240G1X4.0623Y1.6852Z-0.2080
N11250G1X4.0918Y1.6516Z-0.2080
N11260G1X4.1207Y1.6177Z-0.2080
N11270G1X4.1490Y1.5836Z-0.2080
N11280G1X4.1767Y1.5491Z-0.2080
N11290G1X4.2038Y1.5145Z-0.2080
N11300G1X4.2304Y1.4796Z-0.2080
N11310G1X4.2563Y1.4444Z-0.2080
N11320G1X4.2816Y1.4090Z-0.2080
N11330G1X4.3063Y1.3734Z-0.2080
N11340G1X4.3304Y1.3375Z-0.2080
N11350G1X4.3539Y1.3014Z-0.2080
N11360G1X4.3767Y1.2650Z-0.2080
N11370G1X4.3989Y1.2285Z-0.2080
N11380G1X4.4205Y1.1917Z-0.2080
N11390G1X4.4415Y1.1547Z-0.2080
N11400G1X4.4618Y1.1175Z-0.2080
N11410G1X4.4814Y1.0800Z-0.2080
N11420G1X4.5004Y1.0424Z-0.2080
N11430G1X4.5188Y1.0045Z-0.2080
N11440G1X4.5364Y0.9665Z-0.2080
N11450G1X4.5535Y0.9282Z-0.2080
N11460G1X4.5698Y0.8897Z-0.2080
N11470G1X4.5855Y0.8511Z-0.2080
N11480G1X4.6005Y0.8122Z-0.2080
N11490G1X4.6148Y0.7732Z-0.2080
N11500G1X4.6284Y0.7340Z-0.2080
N11510G1X4.6413Y0.6946Z-0.2080
N11520G1X4.6535Y0.6550Z-0.2080
N11530G1X4.6650Y0.6152Z-0.2080
N11540G1X4.6758Y0.5753Z-0.2080
N11550G1X4.6859Y0.5352Z-0.2080
N11560G1X4.6953Y0.4949Z-0.2080
N11570G1X4.7039Y0.4545Z-0.2080
N11580G1X4.7118Y0.4139Z-0.2080
N11590G1X4.7190Y0.3732Z-0.2080
N11600G1X4.7255Y0.3323Z-0.2080
N11610G1X4.7312Y0.2912Z-0.2080
N11620G1X4.7361Y0.2501Z-0.2080
N11630G1X4.7404Y0.2087Z-0.2080
N11640G1X4.7438Y0.1672Z-0.2080
N11650G1X4.7465Y0.1256Z-0.2080
N11660G1X4.7484Y0.0839Z-0.2080
N11670G1X4.7496Y0.0420Z-0.2080
N11680G1X4.7500Y0.0000Z-0.2080
N11690G1X4.7496Y-0.0420Z-0.2080
N11700G1X4.7484Y-0.0839Z-0.2080
N11710G1X4.7465Y-0.1256Z-0.2080
N11720G1X4.7438Y-0.1672Z-0.2080
N11730G1X4.7404Y-0.2087Z-0.2080
N11740G1X4.7361Y-0.2501Z-0.2080
N11750G1X4.7312Y-0.2912Z-0.2080
N11760G1X4.7255Y-0.3323Z-0.2080
N11770G1X4.7190Y-0.3732Z-0.2080
N11780G1X4.7118Y-0.4139Z-0.2080
N11790G1X4.7039Y-0.4545Z-0.2080
N11800G1X4.6953Y-0.4949Z-0.2080
N11810G1X4.6859Y-0.5352Z-0.2080
N11820G1X4.6758Y-0.5753Z-0.2080
N11830G1X4.6650Y-0.6152Z-0.2080
N11840G1X4.6535Y-0.6550Z-0.2080
N11850G1X4.6413Y-0.6946Z-0.2080
N11860G1X4.6284Y-0.7340Z-0.2080
N11870G1X4.6148Y-0.7732Z-0.2080
N11880G1X4.6005Y-0.8122Z-0.2080
N11890G1X4.5855Y-0.8511Z-0.2080
N11900G1X4.5698Y-0.8897Z-0.2080
N11910G1X4.5535Y-0.9282Z-0.2080
N11920G1X4.5364Y-0.9665Z-0.2080
N11930G1X4.5188Y-1.0045Z-0.2080
N11940G1X4.5004Y-1.0424Z-0.2080
N11950G1X4.4814Y-1.0800Z-0.2080
N11960G1X4.4618Y-1.1175Z-0.2080
N11970G1X4.4415Y-1.1547Z-0.2080
N11980G1X4.4205Y-1.1917Z-0.2080
N11990G1X4.3989Y-1.2285Z-0.2080
N12000G1X4.3767Y-1.2650Z-0.2080
N12010G1X4.3539Y-1.3014Z-0.2080
N12020G1X4.3304Y-1.3375Z-0.2080
N12030G1X4.3063Y-1.3734Z-0.2080
N12040G1X4.2816Y-1.4090Z-0.2080
N12050G1X4.2563Y-1.4444Z-0.2080
N12060G1X4.2304Y-1.4796Z-0.2080
N12070G1X4.2038Y-1.5145Z-0.2080
N12080G1X4.1767Y-1.5491Z-0.2080
N12090G1X4.1490Y-1.5836Z-0.2080
N12100G1X4.1207Y-1.6177Z-0.2080
N12110G1X4.0918Y-1.6516Z-0.2080
N12120G1X4.0623Y-1.6852Z-0.2080
N12130G1X4.0323Y-1.7186Z-0.2080
N12140G1X4.0017Y-1.7517Z-0.2080
N12150G1X3.9705Y-1.7845Z-0.2080
N12160G1X3.9388Y-1.8171Z-0.2080
N12170G1X3.8737Y-1.8814Z-0.2080
N12180G1X3.8063Y-1.9445Z-0.2080
N12190G1X3.7369Y-2.0065Z-0.2080
N12200G1X3.6653Y-2.0673Z-0.2080
N12210G1X3.5917Y-2.1269Z-0.2080
N12220G1X3.5160Y-2.1852Z-0.2080
N12230G1X3.4384Y-2.2423Z-0.2080
N12240G1X3.3588Y-2.2981Z-0.2080
N12250G1X3.2772Y-2.3526Z-0.2080
N12260G1X3.1938Y-2.4057Z-0.2080
N12270G1X3.1085Y-2.4575Z-0.2080
N12280G1X3.0214Y-2.5079Z-0.2080
N12290G1X2.9326Y-2.5568Z-0.2080
N12300G1X2.8420Y-2.6043Z-0.2080
N12310G1X2.7497Y-2.6504Z-0.2080
N12320G1X2.6558Y-2.6950Z-0.2080
N12330G1X2.5602Y-2.7380Z-0.2080
N12340G1X2.4630Y-2.7795Z-0.2080
N12350G1X2.3643Y-2.8194Z-0.2080
N12360G1X2.2641Y-2.8577Z-0.2080
N12370G1X2.1624Y-2.8945Z-0.2080
N12380G1X2.0593Y-2.9295Z-0.2080
N12390G1X1.9548Y-2.9629Z-0.2080
N12400G1X1.8489Y-2.9946Z-0.2080
N12410G1X1.7417Y-3.0246Z-0.2080
N12420G1X1.6332Y-3.0528Z-0.2080
N12430G1X1.5235Y-3.0792Z-0.2080
N12440G1X1.4125Y-3.1039Z-0.2080
N12450G1X1.3004Y-3.1267Z-0.2080
N12460G1X1.1871Y-3.1477Z-0.2080
N12470G1X1.0727Y-3.1668Z-0.2080
N12480G1X0.9573Y-3.1840Z-0.2080
N12490G1X0.8408Y-3.1992Z-0.2080
N12500G1X0.7234Y-3.2126Z-0.2080
N12510G1X0.6050Y-3.2239Z-0.2080
N12520G1X0.4857Y-3.2332Z-0.2080
N12530G1X0.3655Y-3.2405Z-0.2080
N12540G1X0.2444Y-3.2458Z-0.2080
N12550G1X0.1226Y-3.2489Z-0.2080
N12560G1X0.0000Y-3.2500Z-0.2080
N12570G1X-0.1226Y-3.2489Z-0.2080
N12580G1X-0.2444Y-3.2458Z-0.2080
N12590G1X-0.3655Y-3.2405Z-0.2080
N12600G1X-0.4857Y-3.2332Z-0.2080
N12610G1X-0.6050Y-3.2239Z-0.2080
N12620G1X-0.7234Y-3.2126Z-0.2080
N12630G1X-0.8408Y-3.1992Z-0.2080
N12640G1X-0.9573Y-3.1840Z-0.2080
N12650G1X-1.0727Y-3.1668Z-0.2080
N12660G1X-1.1871Y-3.1477Z-0.2080
N12670G1X-1.3004Y-3.1267Z-0.2080
N12680G1X-1.4125Y-3.1039Z-0.2080
N12690G1X-1.5235Y-3.0792Z-0.2080
N12700G1X-1.6332Y-3.0528Z-0.2080
N12710G1X-1.7417Y-3.0246Z-0.2080
N12720G1X-1.8489Y-2.9946Z-0.2080
N12730G1X-1.9548Y-2.9629Z-0.2080
N12740G1X-2.0593Y-2.9295Z-0.2080
N12750G1X-2.1624Y-2.8945Z-0.2080
N12760G1X-2.2641Y-2.8577Z-0.2080
N12770G1X-2.3643Y-2.8194Z-0.2080
N12780G1X-2.4630Y-2.7795Z-0.2080
N12790G1X-2.5602Y-2.7380Z-0.2080
N12800G1X-2.6558Y-2.6950Z-0.2080
N12810G1X-2.7497Y-2.6504Z-0.2080
N12820G1X-2.8420Y-2.6043Z-0.2080
N12830G1X-2.9326Y-2.5568Z-0.2080
N12840G1X-3.0214Y-2.5079Z-0.2080
N12850G1X-3.1085Y-2.4575Z-0.2080
N12860G1X-3.1938Y-2.4057Z-0.2080
N12870G1X-3.2772Y-2.3526Z-0.2080
N12880G1X-3.3588Y-2.2981Z-0.2080
N12890G1X-3.4384Y-2.2423Z-0.2080
N12900G1X-3.5160Y-2.1852Z-0.2080
N12910G1X-3.5917Y-2.1269Z-0.2080
N12920G1X-3.6653Y-2.0673Z-0.2080
N12930G1X-3.7369Y-2.0065Z-0.2080
N12940G1X-3.8063Y-1.9445Z-0.2080
N12950G1X-3.8737Y-1.8814Z-0.2080
N12960G1X-3.9388Y-1.8171Z-0.2080
N12970G1X-3.9705Y-1.7845Z-0.2080
N12980G1X-4.0017Y-1.7517Z-0.2080
N12990G1X-4.0323Y-1.7186Z-0.2080
N13000G1X-4.0623Y-1.6852Z-0.2080
N13010G1X-4.0918Y-1.6516Z-0.2080
N13020G1X-4.1207Y-1.6177Z-0.2080
N13030G1X-4.1490Y-1.5836Z-0.2080
N13040G1X-4.1767Y-1.5491Z-0.2080
N13050G1X-4.2038Y-1.5145Z-0.2080
N13060G1X-4.2304Y-1.4796Z-0.2080
N13070G1X-4.2563Y-1.4444Z-0.2080
N13080G1X-4.2816Y-1.4090Z-0.2080
N13090G1X-4.3063Y-1.3734Z-0.2080
N13100G1X-4.3304Y-1.3375Z-0.2080
N13110G1X-4.3539Y-1.3014Z-0.2080
N13120G1X-4.3767Y-1.2650Z-0.2080
N13130G1X-4.3989Y-1.2285Z-0.2080
N13140G1X-4.4205Y-1.1917Z-0.2080
N13150G1X-4.4415Y-1.1547Z-0.2080
N13160G1X-4.4618Y-1.1175Z-0.2080
N13170G1X-4.4814Y-1.0800Z-0.2080
N13180G1X-4.5004Y-1.0424Z-0.2080
N13190G1X-4.5188Y-1.0045Z-0.2080
N13200G1X-4.5364Y-0.9665Z-0.2080
N13210G1X-4.5535Y-0.9282Z-0.2080
N13220G1X-4.5698Y-0.8897Z-0.2080
N13230G1X-4.5855Y-0.8511Z-0.2080
N13240G1X-4.6005Y-0.8122Z-0.2080
N13250G1X-4.6148Y-0.7732Z-0.2080
N13260G1X-4.6284Y-0.7340Z-0.2080
N13270G1X-4.6413Y-0.6946Z-0.2080
N13280G1X-4.6535Y-0.6550Z-0.2080
N13290G1X-4.6650Y-0.6152Z-0.2080
N13300G1X-4.6758Y-0.5753Z-0.2080
N13310G1X-4.6859Y-0.5352Z-0.2080
N13320G1X-4.6953Y-0.4949Z-0.2080
N13330G1X-4.7039Y-0.4545Z-0.2080
N13340G1X-4.7118Y-0.4139Z-0.2080
N13350G1X-4.7190Y-0.3732Z-0.2080
N13360G1X-4.7255Y-0.3323Z-0.2080
N13370G1X-4.7312Y-0.2912Z-0.2080
N13380G1X-4.7361Y-0.2501Z-0.2080
N13390G1X-4.7404Y-0.2087Z-0.2080
N13400G1X-4.7438Y-0.1672Z-0.2080
N13410G1X-4.7465Y-0.1256Z-0.2080
N13420G1X-4.7484Y-0.0839Z-0.2080
N13430G1X-4.7496Y-0.0420Z-0.2080
N13440G1X-4.7500Y0.0000Z-0.2080
N13450G1X-4.7496Y0.0420Z-0.2080
N13460G1X-4.7484Y0.0839Z-0.2080
N13470G1X-4.7465Y0.1256Z-0.2080
N13480G1X-4.7438Y0.1672Z-0.2080
N13490G1X-4.7404Y0.2087Z-0.2080
N13500G1X-4.7361Y0.2501Z-0.2080
N13510G1X-4.7312Y0.2912Z-0.2080
N13520G1X-4.7255Y0.3323Z-0.2080
N13530G1X-4.7190Y0.3732Z-0.2080
N13540G1X-4.7118Y0.4139Z-0.2080
N13550G1X-4.7039Y0.4545Z-0.2080
N13560G1X-4.6953Y0.4949Z-0.2080
N13570G1X-4.6859Y0.5352Z-0.2080
N13580G1X-4.6758Y0.5753Z-0.2080
N13590G1X-4.6650Y0.6152Z-0.2080
N13600G1X-4.6535Y0.6550Z-0.2080
N13610G1X-4.6413Y0.6946Z-0.2080
N13620G1X-4.6284Y0.7340Z-0.2080
N13630G1X-4.6148Y0.7732Z-0.2080
N13640G1X-4.6005Y0.8122Z-0.2080
N13650G1X-4.5855Y0.8511Z-0.2080
N13660G1X-4.5698Y0.8897Z-0.2080
N13670G1X-4.5535Y0.9282Z-0.2080
N13680G1X-4.5364Y0.9665Z-0.2080
N13690G1X-4.5188Y1.0045Z-0.2080
N13700G1X-4.5004Y1.0424Z-0.2080
N13710G1X-4.4814Y1.0800Z-0.2080
N13720G1X-4.4618Y1.1175Z-0.2080
N13730G1X-4.4415Y1.1547Z-0.2080
N13740G1X-4.4205Y1.1917Z-0.2080
N13750G1X-4.3989Y1.2285Z-0.2080
N13760G1X-4.3767Y1.2650Z-0.2080
N13770G1X-4.3539Y1.3014Z-0.2080
N13780G1X-4.3304Y1.3375Z-0.2080
N13790G1X-4.3063Y1.3734Z-0.2080
N13800G1X-4.2816Y1.4090Z-0.2080
N13810G1X-4.2563Y1.4444Z-0.2080
N13820G1X-4.2304Y1.4796Z-0.2080
N13830G1X-4.2038Y1.5145Z-0.2080
N13840G1X-4.1767Y1.5491Z-0.2080
N13850G1X-4.1490Y1.5836Z-0.2080
N13860G1X-4.1207Y1.6177Z-0.2080
N13870G1X-4.0918Y1.6516Z-0.2080
N13880G1X-4.0623Y1.6852Z-0.2080
N13890G1X-4.0323Y1.7186Z-0.2080
N13900G1X-4.0017Y1.7517Z-0.2080
N13910G1X-3.9705Y1.7845Z-0.2080
N13920G1X-3.9388Y1.8171Z-0.2080
N13930G1X-3.8737Y1.8814Z-0.2080
N13940G1X-3.8063Y1.9445Z-0.2080
N13950G1X-3.7369Y2.0065Z-0.2080
N13960G1X-3.6653Y2.0673Z-0.2080
N13970G1X-3.5917Y2.1269Z-0.2080
N13980G1X-3.5160Y2.1852Z-0.2080
N13990G1X-3.4384Y2.2423Z-0.2080
N14000G1X-3.3588Y2.2981Z-0.2080
N14010G1X-3.2772Y2.3526Z-0.2080
N14020G1X-3.1938Y2.4057Z-0.2080
N14030G1X-3.1085Y2.4575Z-0.2080
N14040G1X-3.0214Y2.5079Z-0.2080
N14050G1X-2.9326Y2.5568Z-0.2080
N14060G1X-2.8420Y2.6043Z-0.2080
N14070G1X-2.7497Y2.6504Z-0.2080
N14080G1X-2.6558Y2.6950Z-0.2080
N14090G1X-2.5602Y2.7380Z-0.2080
N14100G1X-2.4630Y2.7795Z-0.2080
N14110G1X-2.3643Y2.8194Z-0.2080
N14120G1X-2.2641Y2.8577Z-0.2080
N14130G1X-2.1624Y2.8945Z-0.2080
N14140G1X-2.0593Y2.9295Z-0.2080
N14150G1X-1.9548Y2.9629Z-0.2080
N14160G1X-1.8489Y2.9946Z-0.2080
N14170G1X-1.7417Y3.0246Z-0.2080
N14180G1X-1.6332Y3.0528Z-0.2080
N14190G1X-1.5235Y3.0792Z-0.2080
N14200G1X-1.4125Y3.1039Z-0.2080
N14210G1X-1.3004Y3.1267Z-0.2080
N14220G1X-1.1871Y3.1477Z-0.2080
N14230G1X-1.0727Y3.1668Z-0.2080
N14240G1X-0.9573Y3.1840Z-0.2080
N14250G1X-0.8408Y3.1992Z-0.2080
N14260G1X-0.7234Y3.2126Z-0.2080
N14270G1X-0.6050Y3.2239Z-0.2080
N14280G1X-0.4857Y3.2332Z-0.2080
N14290G1X-0.3655Y3.2405Z-0.2080
N14300G1X-0.2444Y3.2458Z-0.2080
N14310G1X-0.1226Y3.2489Z-0.2080
N14320G1X0.0000Y3.2500Z-0.2080
N14330G1X0.0000Y3.2500Z-0.2600F30.0
N14340G1X0.1226Y3.2489Z-0.2600F100.0
N14350G1X0.2444Y3.2458Z-0.2600
N14360G1X0.3655Y3.2405Z-0.2600
N14370G1X0.4857Y3.2332Z-0.2600
N14380G1X0.6050Y3.2239Z-0.2600
N14390G1X0.7234Y3.2126Z-0.2600
N14400G1X0.8408Y3.1992Z-0.2600
N14410G1X0.9573Y3.1840Z-0.2600
N14420G1X1.0727Y3.1668Z-0.2600
N14430G1X1.1871Y3.1477Z-0.2600
N14440G1X1.3004Y3.1267Z-0.2600
N14450G1X1.4125Y3.1039Z-0.2600
N14460G1X1.5235Y3.0792Z-0.2600
N14470G1X1.6332Y3.0528Z-0.2600
N14480G1X1.7417Y3.0246Z-0.2600
N14490G1X1.8489Y2.9946Z-0.2600
N14500G1X1.9548Y2.9629Z-0.2600
N14510G1X2.0593Y2.9295Z-0.2600
N14520G1X2.1624Y2.8945Z-0.2600
N14530G1X2.2641Y2.8577Z-0.2600
N14540G1X2.3643Y2.8194Z-0.2600
N14550G1X2.4630Y2.7795Z-0.2600
N14560G1X2.5602Y2.7380Z-0.2600
N14570G1X2.6558Y2.6950Z-0.2600
N14580G1X2.7497Y2.6504Z-0.2600
N14590G1X2.8420Y2.6043Z-0.2600
N14600G1X2.9326Y2.5568Z-0.2600
N14610G1X3.0214Y2.5079Z-0.2600
N14620G1X3.1085Y2.4575Z-0.2600
N14630G1X3.1938Y2.4057Z-0.2600
N14640G1X3.2772Y2.3526Z-0.2600
N14650G1X3.3588Y2.2981Z-0.2600
N14660G1X3.4384Y2.2423Z-0.2600
N14670G1X3.5160Y2.1852Z-0.2600
N14680G1X3.5917Y2.1269Z-0.2600
N14690G1X3.6653Y2.0673Z-0.2600
N14700G1X3.7369Y2.0065Z-0.2600
N14710G1X3.8063Y1.9445Z-0.2600
N14720G1X3.8737Y1.8814Z-0.2600
N14730G1X3.9388Y1.8171Z-0.2600
N14740G1X3.9705Y1.7845Z-0.2600
N14750G1X4.0017Y1.7517Z-0.2600
N14760G1X4.0323Y1.7186Z-0.2600
N14770G1X4.0623Y1.6852Z-0.2600
N14780G1X4.0918Y1.6516Z-0.2600
N14790G1X4.1207Y1.6177Z-0.2600
N14800G1X4.1490Y1.5836Z-0.2600
N14810G1X4.1767Y1.5491Z-0.2600
N14820G1X4.2038Y1.5145Z-0.2600
N14830G1X4.2304Y1.4796Z-0.2600
N14840G1X4.2563Y1.4444Z-0.2600
N14850G1X4.2816Y1.4090Z-0.2600
N14860G1X4.3063Y1.3734Z-0.2600
N14870G1X4.3304Y1.3375Z-0.2600
N14880G1X4.3539Y1.3014Z-0.2600
N14890G1X4.3767Y1.2650Z-0.2600
N14900G1X4.3989Y1.2285Z-0.2600
N14910G1X4.4205Y1.1917Z-0.2600
N14920G1X4.4415Y1.1547Z-0.2600
N14930G1X4.4618Y1.1175Z-0.2600
N14940G1X4.4814Y1.0800Z-0.2600
N14950G1X4.5004Y1.0424Z-0.2600
N14960G1X4.5188Y1.0045Z-0.2600
N14970G1X4.5364Y0.9665Z-0.2600
N14980G1X4.5535Y0.9282Z-0.2600
N14990G1X4.5698Y0.8897Z-0.2600
N15000G1X4.5855Y0.8511Z-0.2600
N15010G1X4.6005Y0.8122Z-0.2600
N15020G1X4.6148Y0.7732Z-0.2600
N15030G1X4.6284Y0.7340Z-0.2600
N15040G1X4.6413Y0.6946Z-0.2600
N15050G1X4.6535Y0.6550Z-0.2600
N15060G1X4.6650Y0.6152Z-0.2600
N15070G1X4.6758Y0.5753Z-0.2600
N15080G1X4.6859Y0.5352Z-0.2600
N15090G1X4.6953Y0.4949Z-0.2600
N15100G1X4.7039Y0.4545Z-0.2600
N15110G1X4.7118Y0.4139Z-0.2600
N15120G1X4.7190Y0.3732Z-0.2600
N15130G1X4.7255Y0.3323Z-0.2600
N15140G1X4.7312Y0.2912Z-0.2600
N15150G1X4.7361Y0.2501Z-0.2600
N15160G1X4.7404Y0.2087Z-0.2600
N15170G1X4.7438Y0.1672Z-0.2600
N15180G1X4.7465Y0.1256Z-0.2600
N15190G1X4.7484Y0.0839Z-0.2600
N15200G1X4.7496Y0.0420Z-0.2600
N15210G1X4.7500Y0.0000Z-0.2600
N15220G1X4.7496Y-0.0420Z-0.2600
N15230G1X4.7484Y-0.0839Z-0.2600
N15240G1X4.7465Y-0.1256Z-0.2600
N15250G1X4.7438Y-0.1672Z-0.2600
N15260G1X4.7404Y-0.2087Z-0.2600
N15270G1X4.7361Y-0.2501Z-0.2600
N15280G1X4.7312Y-0.2912Z-0.2600
N15290G1X4.7255Y-0.3323Z-0.2600
N15300G1X4.7190Y-0.3732Z-0.2600
N15310G1X4.7118Y-0.4139Z-0.2600
N15320G1X4.7039Y-0.4545Z-0.2600
N15330G1X4.6953Y-0.4949Z-0.2600
N15340G1X4.6859Y-0.5352Z-0.2600
N15350G1X4.6758Y-0.5753Z-0.2600
N15360G1X4.6650Y-0.6152Z-0.2600
N15370G1X4.6535Y-0.6550Z-0.2600
N15380G1X4.6413Y-0.6946Z-0.2600
N15390G1X4.6284Y-0.7340Z-0.2600
N15400G1X4.6148Y-0.7732Z-0.2600
N15410G1X4.6005Y-0.8122Z-0.2600
N15420G1X4.5855Y-0.8511Z-0.2600
N15430G1X4.5698Y-0.8897Z-0.2600
N15440G1X4.5535Y-0.9282Z-0.2600
N15450G1X4.5364Y-0.9665Z-0.2600
N15460G1X4.5188Y-1.0045Z-0.2600
N15470G1X4.5004Y-1.0424Z-0.2600
N15480G1X4.4814Y-1.0800Z-0.2600
N15490G1X4.4618Y-1.1175Z-0.2600
N15500G1X4.4415Y-1.1547Z-0.2600
N15510G1X4.4205Y-1.1917Z-0.2600
N15520G1X4.3989Y-1.2285Z-0.2600
N15530G1X4.3767Y-1.2650Z-0.2600
N15540G1X4.3539Y-1.3014Z-0.2600
N15550G1X4.3304Y-1.3375Z-0.2600
N15560G1X4.3063Y-1.3734Z-0.2600
N15570G1X4.2816Y-1.4090Z-0.2600
N15580G1X4.2563Y-1.4444Z-0.2600
N15590G1X4.2304Y-1.4796Z-0.2600
N15600G1X4.2038Y-1.5145Z-0.2600
N15610G1X4.1767Y-1.5491Z-0.2600
N15620G1X4.1490Y-1.5836Z-0.2600
N15630G1X4.1207Y-1.6177Z-0.2600
N15640G1X4.0918Y-1.6516Z-0.2600
N15650G1X4.0623Y-1.6852Z-0.2600
N15660G1X4.0323Y-1.7186Z-0.2600
N15670G1X4.0017Y-1.7517Z-0.2600
N15680G1X3.9705Y-1.7845Z-0.2600
N15690G1X3.9388Y-1.8171Z-0.2600
N15700G1X3.8737Y-1.8814Z-0.2600
N15710G1X3.8063Y-1.9445Z-0.2600
N15720G1X3.7369Y-2.0065Z-0.2600
N15730G1X3.6653Y-2.0673Z-0.2600
N15740G1X3.5917Y-2.1269Z-0.2600
N15750G1X3.5160Y-2.1852Z-0.2600
N15760G1X3.4384Y-2.2423Z-0.2600
N15770G1X3.3588Y-2.2981Z-0.2600
N15780G1X3.2772Y-2.3526Z-0.2600
N15790G1X3.1938Y-2.4057Z-0.2600
N15800G1X3.1085Y-2.4575Z-0.2600
N15810G1X3.0214Y-2.5079Z-0.2600
N15820G1X2.9326Y-2.5568Z-0.2600
N15830G1X2.8420Y-2.6043Z-0.2600
N15840G1X2.7497Y-2.6504Z-0.2600
N15850G1X2.6558Y-2.6950Z-0.2600
N15860G1X2.5602Y-2.7380Z-0.2600
N15870G1X2.4630Y-2.7795Z-0.2600
N15880G1X2.3643Y-2.8194Z-0.2600
N15890G1X2.2641Y-2.8577Z-0.2600
N15900G1X2.1624Y-2.8945Z-0.2600
N15910G1X2.0593Y-2.9295Z-0.2600
N15920G1X1.9548Y-2.9629Z-0.2600
N15930G1X1.8489Y-2.9946Z-0.2600
N15940G1X1.7417Y-3.0246Z-0.2600
N15950G1X1.6332Y-3.0528Z-0.2600
N15960G1X1.5235Y-3.0792Z-0.2600
N15970G1X1.4125Y-3.1039Z-0.2600
N15980G1X1.3004Y-3.1267Z-0.2600
N15990G1X1.1871Y-3.1477Z-0.2600
N16000G1X1.0727Y-3.1668Z-0.2600
N16010G1X0.9573Y-3.1840Z-0.2600
N16020G1X0.8408Y-3.1992Z-0.2600
N16030G1X0.7234Y-3.2126Z-0.2600
N16040G1X0.6050Y-3.2239Z-0.2600
N16050G1X0.4857Y-3.2332Z-0.2600
N16060G1X0.3655Y-3.2405Z-0.2600
N16070G1X0.2444Y-3.2458Z-0.2600
N16080G1X0.1226Y-3.2489Z-0.2600
N16090G1X0.0000Y-3.2500Z-0.2600
N16100G1X-0.1226Y-3.2489Z-0.2600
N16110G1X-0.2444Y-3.2458Z-0.2600
N16120G1X-0.3655Y-3.2405Z-0.2600
N16130G1X-0.4857Y-3.2332Z-0.2600
N16140G1X-0.6050Y-3.2239Z-0.2600
N16150G1X-0.7234Y-3.2126Z-0.2600
N16160G1X-0.8408Y-3.1992Z-0.2600
N16170G1X-0.9573Y-3.1840Z-0.2600
N16180G1X-1.0727Y-3.1668Z-0.2600
N16190G1X-1.1871Y-3.1477Z-0.2600
N16200G1X-1.3004Y-3.1267Z-0.2600
N16210G1X-1.4125Y-3.1039Z-0.2600
N16220G1X-1.5235Y-3.0792Z-0.2600
N16230G1X-1.6332Y-3.0528Z-0.2600
N16240G1X-1.7417Y-3.0246Z-0.2600
N16250G1X-1.8489Y-2.9946Z-0.2600
N16260G1X-1.9548Y-2.9629Z-0.2600
N16270G1X-2.0593Y-2.9295Z-0.2600
N16280G1X-2.1624Y-2.8945Z-0.2600
N16290G1X-2.2641Y-2.8577Z-0.2600
N16300G1X-2.3643Y-2.8194Z-0.2600
N16310G1X-2.4630Y-2.7795Z-0.2600
N16320G1X-2.5602Y-2.7380Z-0.2600
N16330G1X-2.6558Y-2.6950Z-0.2600
N16340G1X-2.7497Y-2.6504Z-0.2600
N16350G1X-2.8420Y-2.6043Z-0.2600
N16360G1X-2.9326Y-2.5568Z-0.2600
N16370G1X-3.0214Y-2.5079Z-0.2600
N16380G1X-3.1085Y-2.4575Z-0.2600
N16390G1X-3.1938Y-2.4057Z-0.2600
N16400G1X-3.2772Y-2.3526Z-0.2600
N16410G1X-3.3588Y-2.2981Z-0.2600
N16420G1X-3.4384Y-2.2423Z-0.2600
N16430G1X-3.5160Y-2.1852Z-0.2600
N16440G1X-3.5917Y-2.1269Z-0.2600
N16450G1X-3.6653Y-2.0673Z-0.2600
N16460G1X-3.7369Y-2.0065Z-0.2600
N16470G1X-3.8063Y-1.9445Z-0.2600
N16480G1X-3.8737Y-1.8814Z-0.2600
N16490G1X-3.9388Y-1.8171Z-0.2600
N16500G1X-3.9705Y-1.7845Z-0.2600
N16510G1X-4.0017Y-1.7517Z-0.2600
N16520G1X-4.0323Y-1.7186Z-0.2600
N16530G1X-4.0623Y-1.6852Z-0.2600
N16540G1X-4.0918Y-1.6516Z-0.2600
N16550G1X-4.1207Y-1.6177Z-0.2600
N16560G1X-4.1490Y-1.5836Z-0.2600
N16570G1X-4.1767Y-1.5491Z-0.2600
N16580G1X-4.2038Y-1.5145Z-0.2600
N16590G1X-4.2304Y-1.4796Z-0.2600
N16600G1X-4.2563Y-1.4444Z-0.2600
N16610G1X-4.2816Y-1.4090Z-0.2600
N16620G1X-4.3063Y-1.3734Z-0.2600
N16630G1X-4.3304Y-1.3375Z-0.2600
N16640G1X-4.3539Y-1.3014Z-0.2600
N16650G1X-4.3767Y-1.2650Z-0.2600
N16660G1X-4.3989Y-1.2285Z-0.2600
N16670G1X-4.4205Y-1.1917Z-0.2600
N16680G1X-4.4415Y-1.1547Z-0.2600
N16690G1X-4.4618Y-1.1175Z-0.2600
N16700G1X-4.4814Y-1.0800Z-0.2600
N16710G1X-4.5004Y-1.0424Z-0.2600
N16720G1X-4.5188Y-1.0045Z-0.2600
N16730G1X-4.5364Y-0.9665Z-0.2600
N16740G1X-4.5535Y-0.9282Z-0.2600
N16750G1X-4.5698Y-0.8897Z-0.2600
N16760G1X-4.5855Y-0.8511Z-0.2600
N16770G1X-4.6005Y-0.8122Z-0.2600
N16780G1X-4.6148Y-0.7732Z-0.2600
N16790G1X-4.6284Y-0.7340Z-0.2600
N16800G1X-4.6413Y-0.6946Z-0.2600
N16810G1X-4.6535Y-0.6550Z-0.2600
N16820G1X-4.6650Y-0.6152Z-0.2600
N16830G1X-4.6758Y-0.5753Z-0.2600
N16840G1X-4.6859Y-0.5352Z-0.2600
N16850G1X-4.6953Y-0.4949Z-0.2600
N16860G1X-4.7039Y-0.4545Z-0.2600
N16870G1X-4.7118Y-0.4139Z-0.2600
N16880G1X-4.7190Y-0.3732Z-0.2600
N16890G1X-4.7255Y-0.3323Z-0.2600
N16900G1X-4.7312Y-0.2912Z-0.2600
N16910G1X-4.7361Y-0.2501Z-0.2600
N16920G1X-4.7404Y-0.2087Z-0.2600
N16930G1X-4.7438Y-0.1672Z-0.2600
N16940G1X-4.7465Y-0.1256Z-0.2600
N16950G1X-4.7484Y-0.0839Z-0.2600
N16960G1X-4.7496Y-0.0420Z-0.2600
N16970G1X-4.7500Y0.0000Z-0.2600
N16980G1X-4.7496Y0.0420Z-0.2600
N16990G1X-4.7484Y0.0839Z-0.2600
N17000G1X-4.7465Y0.1256Z-0.2600
N17010G1X-4.7438Y0.1672Z-0.2600
N17020G1X-4.7404Y0.2087Z-0.2600
N17030G1X-4.7361Y0.2501Z-0.2600
N17040G1X-4.7312Y0.2912Z-0.2600
N17050G1X-4.7255Y0.3323Z-0.2600
N17060G1X-4.7190Y0.3732Z-0.2600
N17070G1X-4.7118Y0.4139Z-0.2600
N17080G1X-4.7039Y0.4545Z-0.2600
N17090G1X-4.6953Y0.4949Z-0.2600
N17100G1X-4.6859Y0.5352Z-0.2600
N17110G1X-4.6758Y0.5753Z-0.2600
N17120G1X-4.6650Y0.6152Z-0.2600
N17130G1X-4.6535Y0.6550Z-0.2600
N17140G1X-4.6413Y0.6946Z-0.2600
N17150G1X-4.6284Y0.7340Z-0.2600
N17160G1X-4.6148Y0.7732Z-0.2600
N17170G1X-4.6005Y0.8122Z-0.2600
N17180G1X-4.5855Y0.8511Z-0.2600
N17190G1X-4.5698Y0.8897Z-0.2600
N17200G1X-4.5535Y0.9282Z-0.2600
N17210G1X-4.5364Y0.9665Z-0.2600
N17220G1X-4.5188Y1.0045Z-0.2600
N17230G1X-4.5004Y1.0424Z-0.2600
N17240G1X-4.4814Y1.0800Z-0.2600
N17250G1X-4.4618Y1.1175Z-0.2600
N17260G1X-4.4415Y1.1547Z-0.2600
N17270G1X-4.4205Y1.1917Z-0.2600
N17280G1X-4.3989Y1.2285Z-0.2600
N17290G1X-4.3767Y1.2650Z-0.2600
N17300G1X-4.3539Y1.3014Z-0.2600
N17310G1X-4.3304Y1.3375Z-0.2600
N17320G1X-4.3063Y1.3734Z-0.2600
N17330G1X-4.2816Y1.4090Z-0.2600
N17340G1X-4.2563Y1.4444Z-0.2600
N17350G1X-4.2304Y1.4796Z-0.2600
N17360G1X-4.2038Y1.5145Z-0.2600
N17370G1X-4.1767Y1.5491Z-0.2600
N17380G1X-4.1490Y1.5836Z-0.2600
N17390G1X-4.1207Y1.6177Z-0.2600
N17400G1X-4.0918Y1.6516Z-0.2600
N17410G1X-4.0623Y1.6852Z-0.2600
N17420G1X-4.0323Y1.7186Z-0.2600
N17430G1X-4.0017Y1.7517Z-0.2600
N17440G1X-3.9705Y1.7845Z-0.2600
N17450G1X-3.9388Y1.8171Z-0.2600
N17460G1X-3.8737Y1.8814Z-0.2600
N17470G1X-3.8063Y1.9445Z-0.2600
N17480G1X-3.7369Y2.0065Z-0.2600
N17490G1X-3.6653Y2.0673Z-0.2600
N17500G1X-3.5917Y2.1269Z-0.2600
N17510G1X-3.5160Y2.1852Z-0.2600
N17520G1X-3.4384Y2.2423Z-0.2600
N17530G1X-3.3588Y2.2981Z-0.2600
N17540G1X-3.2772Y2.3526Z-0.2600
N17550G1X-3.1938Y2.4057Z-0.2600
N17560G1X-3.1085Y2.4575Z-0.2600
N17570G1X-3.0214Y2.5079Z-0.2600
N17580G1X-2.9326Y2.5568Z-0.2600
N17590G1X-2.8420Y2.6043Z-0.2600
N17600G1X-2.7497Y2.6504Z-0.2600
N17610G1X-2.6558Y2.6950Z-0.2600
N17620G1X-2.5602Y2.7380Z-0.2600
N17630G1X-2.4630Y2.7795Z-0.2600
N17640G1X-2.3643Y2.8194Z-0.2600
N17650G1X-2.2641Y2.8577Z-0.2600
N17660G1X-2.1624Y2.8945Z-0.2600
N17670G1X-2.0593Y2.9295Z-0.2600
N17680G1X-1.9548Y2.9629Z-0.2600
N17690G1X-1.8489Y2.9946Z-0.2600
N17700G1X-1.7417Y3.0246Z-0.2600
N17710G1X-1.6332Y3.0528Z-0.2600
N17720G1X-1.5235Y3.0792Z-0.2600
N17730G1X-1.4125Y3.1039Z-0.2600
N17740G1X-1.3004Y3.1267Z-0.2600
N17750G1X-1.1871Y3.1477Z-0.2600
N17760G1X-1.0727Y3.1668Z-0.2600
N17770G1X-0.9573Y3.1840Z-0.2600
N17780G1X-0.8408Y3.1992Z-0.2600
N17790G1X-0.7234Y3.2126Z-0.2600
N17800G1X-0.6050Y3.2239Z-0.2600
N17810G1X-0.4857Y3.2332Z-0.2600
N17820G1X-0.3655Y3.2405Z-0.2600
N17830G1X-0.2444Y3.2458Z-0.2600
N17840G1X-0.1226Y3.2489Z-0.2600
N17850G1X0.0000Y3.2500Z-0.2600
N17860G00X0.0000Y3.2500Z0.2000
N17870G00Z0.8000
N17880G00X0.0000Y0.0000
N17890M09
N17900M30
( Material Size)
(Profile 1)
N110G70G91.1
N120T1M06
N140G00G43Z0.8000H1
N150S12000M03
N170()
N180G94
N17870G00Z0.8000
N17890M09
N17900M30
- Model of CNC Machine: RF31, 4X8 Router both CNC
Re: y is off .120
The code runs fine and is accurate here on all 5 revolutions of it.
Need to look at your machine.
Cheers
Ray
Cheers
Ray
Re: y is off .120
thanks Ray..........any idea where to start? what would I ask to search for the issue?
Re: y is off .120
Well you said you cut a 4" circle and it turned out fine so I would cut a 6.5" circle and see how that works.
If that works ok then was the file you posted here the exact one you loaded into Mach3 or one you redid later?
Cheers
Ray
Cheers
Ray
Re: y is off .120
Rdean ....actually it was a new g code and not the original one that I cut. the original was even on a different computer. i.ll use this g code and cut a new piece and see what gives with that. I get a little confused with the troubleshooting of my problems and tend not to be able to go through all the steps correctly. thanks Dan
