Is There A Source To Find Bit Vectors of CNC Bits
Postby roper » Tue Jun 02, 2015 1:52 pm
I am new at the CNC process but learning. I am using Cut2d Desktop V 8.017. The computer software has a few pre-loaded cnc bits loaded but obviously there are a lot of bits out there. In one of vector's tutorials it talks about creating a bit vector for adding to your tool base. Just wondering if there is any already created bit vectors (eps, or other formats) that are available to be downloaded, either free or for a price. Or if there are quality images; jpg, bmp etc that are available to be downloaded and saved and then converted using, i.e. inkscape to create the vectors. Thanks, Roger
roper
Model of CNC Machine: piranha_1000
Re: Is There A Source To Find Bit Vectors of CNC Bits
Postby Adrian » Tue Jun 02, 2015 5:05 pm
Most tool manufacturers have them on their website (the one I use most is here - http://www.wealdentool.com/acatalog/outline.pdf ) but to be honest most bits used in CNC are the same basic shapes (ball, endmill, v-bit, roundover).
In the Vectric software you can't define an undercut so tool likes slot cutters, keyhole cutters etc can't be setup and you just use an endmill definition instead.
Postby Leo » Tue Jun 02, 2015 5:25 pm
The tool shapes are pretty easy to create.
I usually measure and create the vector lines
A form shape may be a little challenging depending on your CAD and measuring skills.
An ogee curve takes 10-15 minutes
You cannot do a dovetail
the top cannot be smaller than the bottom.
www.leosworkshop.com
Leo
Postby sailor10 » Thu Aug 17, 2017 7:55 pm
Is this still true for the Cut2D desktop v9. In one of the tutorials, I believe it said that form tools could be created, but I am having a heck of a time. Just want a couple of edge designs like round overs and decorative molding edges.posting.php?mode=reply&f=18&t=22570#
sailor10
Model of CNC Machine: Home Built
Postby Adrian » Thu Aug 17, 2017 8:15 pm
V9 has the same limitations on form tools as previous versions. You cannot create one that forms an undercut.
Postby sailor10 » Thu Aug 17, 2017 8:45 pm
I updated from v 1.5 to v9, in 1.5 you could not add any form tools. OK, I got a tapered edge to install, thank you for your assistance. Just took some patience to make it happen.
sailor10
Return to Cut2D - General
