RPM Router Speed
- Model of CNC Machine: CNC Shark II
RPM Router Speed
When watching the Vectric video's I see the software allows for the adjustment of the router RPM speed, I cannot figure out how that works, if I look at the photo of CNC PIRANHA machine looks like router is plugged into wall outlet, or is it plugged into a control box that control speed through varing power?
Re: RPM Router Speed
It all depends on the control software and hardware in use. Cut2D works with many different machines some of which have spindles with variable frequency drives that often have direct control of speed from the control software.
Machines with routers generally rely on the speed being set by the operator rather than the via the control software although it is possible to buy add-ons that will work with control software such as Mach3.
- Model of CNC Machine: piranha
Hi, I just purchased the Piranha and was surprised that the software does not control the router speed. The Piranha comes with a Bosch Colt router which requires a manual speed adjustment. I don't consider this a big problem since I can still adjust the speed in an attempt to get the optimum router speed and feed rate combination.
Ed
Ed
Ed, I saw some of your previous posts and wondering if you could offer some input: I see that you bought the Prinaha,did you get it yet, are you happy with it? I see some response saying it unproven, I keep thing about buy "My second machine first".
Hi, yes I have had it for about a week, but have not made any finished products yet -- trying to get used to the machine and software. However, I did notice one thing. I made some cuts on 1/4 inch thick MDF where I cut 1/8 inch thick with each pass. The edges were not quite smooth, requiring some sanding. Perhaps this is caused by some unwanted instability of the gantry. But I need to do some additional testing before coming to any conclusions.
Ed
Ed
- Model of CNC Machine: CNC Router
Harbor Freight sells a speed control for under $15 and it works quite well
