how to cut 1/4" circle with 1/4" bit
Postby cromag27 » Sat Aug 24, 2019 9:33 pm
i basically want the bit to plunge through the material and back out again. i use illustrator to design, and pro to cut. i 'm not sure how to create the mark in illustrator and then what to select in c2dpro (on?).
thanks!
cromag27
Model of CNC Machine: nwa shark hd3 ext mod
Re: how to cut 1/4" circle with 1/4" bit
Postby IslaWW » Sat Aug 24, 2019 10:30 pm
Use the drilling toolpath
CNC Technology & Training
IslaWW
Postby cromag27 » Sun Aug 25, 2019 12:09 am
easy, thanks!
cromag27
Postby lward1988 » Wed Sep 11, 2019 9:35 pm
Yes, just make sure you have a 1/4" bit in there, select the circle you've created, and then use the "drilling" icon...set your depth same as the material you're cutting and it does the rest. Just remember, on the "drilling" icon, it basically in just a simply plunge down effect, I don't think the software cares the size of the circle you made as it only goes up and down in "Z axis"...Also, when using this drilling feature, make sure there is a (+) inside the circle after setting the tooling path. This lets you know you're good to go! I use drilling all day everyday for the products we make...great feature!
lward1988
Model of CNC Machine: laguna swift 4x8
Postby cromag27 » Wed Sep 11, 2019 9:48 pm
great thank you!!!
cromag27
Return to Cut2D - General
Users browsing this forum: Bing [Bot] and 4 guests
