Material size and toolpath origins clashing
Postby Richard93Vogue » Fri Apr 20, 2018 6:25 am
Hello,
I'm very new to Cut2d, but not new to CNC and Gcode. The problem I am having is that even when I set the material size and the origin point of my job to the bottom left corner of the material, when I transfer the file to the machine it ignores the material dimensions and starts cutting from X0 Y0 instead of the proper coordinates.
Is there a setting I am missing somewhere???
thanks
Richard.
Richard93Vogue
Model of CNC Machine: Multicam vacuum table router
Re: Material size and toolpath origins clashing
Postby Adrian » Fri Apr 20, 2018 7:18 am
Are you using the correct post processor for your machine?
Postby ger21 » Fri Apr 20, 2018 11:52 am
Are you sure it's not just going to a home position first? I know some posts do that.
Gerry
ger21
Postby Leo » Fri Apr 20, 2018 12:34 pm
If you are setting the lower left corner in Vectric as the origin - that is X0, Y0 in the program
Then you ALSO set the lower left corner in the machine control as the origin on the actual material, that will be X0, Y0 on the material.
That way - X0 & Y0 is the proper location.
Generally - a program will move the tool to the X0 & Y0 position before it moves to cutting positions.
If you are seeing the tool move to the lower left corner before cutting and above the material - that is correct.
www.leosworkshop.com
Leo
Postby Richard93Vogue » Fri May 11, 2018 1:53 am
Thanks everyone. What I have found is that the 'Job size' as set in the program (essentially the stock around the finished part) is not recognised automatically in the toolpath calculations. Rather I need to use offsets to position in the material.
Anyway, I have worked out a system that works for me and my machine and have a post processor that works.
Thanks again.
Richard.
Richard93Vogue
Postby Adrian » Fri May 11, 2018 7:27 am
The position of the toolpath is set by the position of the vector it's based on.
Postby adze_cnc » Fri May 11, 2018 4:57 pm
How about posting two sample files and let us know what post processor you are using?
One file that you figure doesn't work where:
Richard93Vogue wrote:...the 'Job size' as set in the program (essentially the stock around the finished part) is not recognised automatically in the toolpath calculations.
And one file that you figure does work because:
Richard93Vogue wrote:...I need to use offsets to position in the material.
That way people can have a better understanding of what's happening to you. That you have to do some convoluted work-around while others don't is of interest.
Return to Cut2D - General
