This one is just about an hour off the table. Both of my boys have always liked this picture of their mom from long ago, so thought I'd send each of them a litho for Christmas. One down, one to go.
Mike
Christmas Present for my sons
- Penman
- Model of CNC Machine: Shopbot B 32 Alpha
Re: Christmas Present for my sons
Hi Mike,
Beautiful job. Everything has appeared so clear and detailed. Would you mind sharing a few detapls?
Thanks for showing, really got my juices's flowing.
Roger.
Roger.
Penman wrote:Hi Mike,
Roger.
Same settings as usual.
.25" Champagne White Corian.
PVC Settings:
Tool: .031 Ballnose
Cut depth per pass: .21
Max cut depth: .2
Line Spacing: 10%
Cut Angle: 310 deg
Feed Rate: 50 IPM
Plunge: 20
Invert Black / White then calculate
Actually use a .25" dia 30deg vcarve bit
Frame:
Simple box frame using 4/4 thick stock that was ripped to 2" wide and cut with 45 deg mitres to fit litho stock
.25 dado cut .125 deep approx .25 back from leading edge on the face.
.25 rabbet cut on back face that is .25 deep to accept backer board.
on the smaller 5x7 litho, used cool white LED's hot glued on inside of frame on the left and right side.
STGC(SW/AW) M. Wenman USN Ret.
1982 - 2005
1982 - 2005
- Penman
Thank you Mike,
I have printed your settings off. Now to try and get one done myself. If I can get anywhere near the quality that you have I will be more than happy.
Thanks again,
Roger.
Thanks again,
Roger.
