Tribute to Mom
Tribute to Mom
It has been a while since there has been a new post so......
Here's a Lithopane I did as a tribute to my mom whom passed away 5 years ago from cancer.
I found a photo that was taken of her when she was around 17 yrs old I think and set it up into PhotoVCarve and then imported it into Aspire.
I found the poem on this forum some time ago I believe, but the words fit her perfectly so did the text in Aspire as well.
Frame is just a simple Walnut box that has white led's around it's perimiter inside.
Litho settings:
.25 Champagne White Corian
told PVC it was .21
Selected .031 ballnose with a max cut depth of .20 at 315 deg with X0Y0 at lower left corner and Z0 just at the tope surface.
cut at 50ipm with a .25 dia 30 deg vcarve bit.
Cut time just a bit over 5 hours
Mike
Litho settings:
told PVC it was .21
Mike
STGC(SW/AW) M. Wenman USN Ret.
1982 - 2005
1982 - 2005
- Penman
- Model of CNC Machine: Shopbot B 32 Alpha
Re: Tribute to Mom
Hi Mike,
thanks for posting, and the information. Great piece of work. I have wanted to do a litho myself for some time. Have not done one yet but yours has certainly revived my interest. Thank you.
Roger.
Roger.
- RoboCNC
- Model of CNC Machine: RoboCNC X1 Router / Optimum BF20L
Re: Tribute to Mom
Nice work Mike...
But i think you have to check your leadscrew pitch settings.
Maybe its my eyes, but if not it seems the photo is not rectangular ...
I had the same problem some time ago, this was because the steps/inch where a really small amount of...
this way as the tool does a litho, it has to go back and forward a lot of times, and the result is a parallelogram shape (don't know the correct English word)
Re: Tribute to Mom
Just noticed your post as i dont get on everyday, but the only leadscrew on my CNC is the Z-axis. X and Y are sprocket/chain driven. may have to slip one of the X axis chains just a bit to get it inline with the opposing side.RoboCNC wrote:Nice work Mike...
Mike
1982 - 2005
1982 - 2005
- RoboCNC
Re: Tribute to Mom
Well its at least worth testing it indeed...., but further more its a great Tribute...
Re: Tribute to Mom
did some looking at the litho this evening and the problem is definitely in the Y-Axis, so not sure where to go or what needs to be done at this point with that chain drive. It's starting out as you notices as an example with the upper left at X0 Y6.68 and gradually increases in Y where the The upper right is at X5 Y7.RoboCNC wrote:Nice work Mike...
hmm perplexing as to why Y0 remains constant along X yet Y increases along X at the top.
1982 - 2005
1982 - 2005
Re: Tribute to Mom
Mike, if the X chains are pulling the two gantry sides at slightly different rates, it could be racking the gantry and messing with the Y. Do you have one motor for both sides, or dual motors? Also, if the two X chains are not tensioned equally then the two sides would have different calibrations, again leading to racking. 0.32" seems like a lot to lose, but it amounts to about 1 unit of a #25 chain.MikeUSNRet wrote:
Cheers!
Paul Rowntree
Re: Tribute to Mom
Am using dual motors and #25 chain.PaulRowntree wrote:Mike, if the X chains are pulling the two gantry sides at slightly different rates, it could be racking the gantry and messing with the Y. Do you have one motor for both sides, or dual motors? Also, if the two X chains are not tensioned equally then the two sides would have different calibrations, again leading to racking. 0.32" seems like a lot to lose, but it amounts to about 1 unit of a #25 chain.MikeUSNRet wrote:
Cheers!
1982 - 2005
1982 - 2005
- RoboCNC
Re: Tribute to Mom
Why are you sure its in the Y axis...? because the picture is shifted in that direction?
If so, thats does not have to mean its in the Y axis... because you probably used a 45degree angle attack on the litho...
I know because i had the same problem, and did make the same mistake by thinking it must be in the Y axis.
If you want to make sure...., do 2 new litho's (in wood for instance) and take a 0degree raster, and a 90degree raster...
Re: Tribute to Mom
my X0Y0Z0 was in the lower left corner and angle was cut at 315 deg (-45).RoboCNC wrote:Why are you sure its in the Y axis...? because the picture is shifted in that direction?
It would appear that it is Y axis that is gaining steps along X, but I do see how the culprit could be in X with the gantry twisting slightly due to force on the bit during the cut.
next will be determining how to correct the error.
1982 - 2005
1982 - 2005
- esteeme1
- Model of CNC Machine: Cobra 404 ATC; ROMAX WD-1; Shark
Re: Tribute to Mom
Mike,
Very well done! Isn't it funny how our Moms can continue to inspire.
Jim Darlas
"Can Do!"
http://www.esteemedwoodcrafts.com/
http://www.esteemedplaques.com/
"Can Do!"
