Melamine
Melamine
Postby grompot » Thu Jun 20, 2019 8:58 pm
I was doing carvings on Melamine a few months back. I plan to use this technique on my kitchen cabinets.
https://www.instructables.com/id/Photo- ... -Drawings/
grompot
Model of CNC Machine: Croncraft
Re: Melamine
Postby Jhodge76 » Fri Jun 21, 2019 4:27 pm
I really enjoy doing things like this with PVC, I do it slightly differently than those directions though but it's fun to try different settings and techniques to see how they turn out.
The elephant is a pencil drawing and the school is from a photograph.
Jhodge76
Re: Melamine
Postby gstofira@neo.rr.com » Thu Sep 26, 2019 9:10 pm
Would you please list the settings you used for the cuts. Thanks. George.
gstofira@neo.rr.com
Model of CNC Machine: Legacy Arty
Re: Melamine
Postby ezurick » Fri Sep 27, 2019 11:47 am
gstofira@neo.rr.com wrote:Would you please list the settings you used for the cuts. Thanks. George.
Also, what did you use for a finish to get the darker shades?
And what wood is that?
ezurick
Re: Melamine
Postby Jhodge76 » Mon Sep 30, 2019 5:06 pm
The settings I used is about 14% line spacing, this varies based on size or level of detail I want, and I usually use a .125 ball nose. Sometimes I cut at a .05 or .03 depth, this also depends on the picture. After it's cut I cover it in paint and then sand off the top until I get the desired shading.
These were done in pine.
I hope that helps.
Jonathan
Jhodge76
Re: Melamine
Postby Jan.vanderlinden » Fri Oct 11, 2019 8:15 pm
Do you use any type of sealer before painting to avoid bleeding?
I've learned so much from my mistakes, I'm thinking of making a few more.
Jan.vanderlinden
Model of CNC Machine: Xcarve
Re: Melamine
Postby Jhodge76 » Mon Oct 14, 2019 4:45 pm
Not on these. I usually use chalk paint because it's thicker and it doesn't seem to bleed at all.
Jhodge76
