Corian Color Lithophane Lamp
Postby BSImages » Sat Mar 29, 2008 5:29 am
Corian Color Lithophane Lamp!
Try saying that fast 5 times!
I made the entire lamp out of 1/4 inch Corian and cut the Litho with a 45 degree V-bit. In PhotoVCarve I set it up as a 0.03 ball nose bit with max depth at 0.15" and line spacing at 16%. I set Z-zero at -0.05, with the max depth at 0.15" I got more of a 3D effect than I would have at 0.1". I used a 23watt fluorescent light bulb and an outdoor light fixture.
BSImages
Model of CNC Machine: Home designed and built.
Postby lovebugjunkie » Sat Mar 29, 2008 5:47 am
Very nice, I like your idea of making the lamp out of corian.
lovebugjunkie
Model of CNC Machine: Romaxx HS1
Postby RoutnAbout » Sat Mar 29, 2008 2:24 pm
Great Job Bill...
Seriously, looks great. Can't wait to try that colored overly on the back.
________
Don
RoutnAbout
Model of CNC Machine: Old Bot with a Rope Pull Start Spindle
Postby Rusty » Sun Mar 30, 2008 5:21 am
Hey guys:
I don't understand how you get the colors. Could you please explain.
Thanks.
Rusty
Rusty
Model of CNC Machine: Homebuilt
Postby ClaudioG » Sun Mar 30, 2008 8:52 am
This will explain it Rusty.
http://vectric.com/forum/viewtopic.php?t=2824
Very nice work Bill.
Cheers
Claudio
ClaudioG
Postby Rusty » Sun Mar 30, 2008 1:29 pm
Nice work Bill.
Thanks for the info guys. Hope to make one soon.
Rusty
Rusty
Postby BSImages » Mon Mar 31, 2008 3:18 am
I used HP color transparency film.
1st I converted the full color image into a CMYK image and then deleted the "K" channel which is the black or shades of gray that the lithophane already represents.
Then I glued the transparency to the back of the lithophane being sure to line it up just right. I used 3M's 77 spray adhesive.
I then gave it a light coat of mat white lacquer paint over the transparency so that the color "magically" disappears when the light is turned off... :idea:
BSImages
Postby crocky » Tue Apr 01, 2008 11:42 pm
Hi Bill,
Very nice eagle there and top technique too, I will have to try it :)
Cheers,
Bob
Aspire, VCarve Pro, PhotoVCarve
Blog: http://www.ocm.com.au/wordpress/
crocky
Return to PhotoVCarve - Gallery
