once you have the layout down... you can almost print money...
I bought this program to add to other programing we had in the shop.
For the most part I just build canoes (which these days gets put on hold), now I find that if you give on of these to the right person, the advertising is worth the $10 in materials.
I have sold over 60 in the past 30 days
lighting up ...this is fun stuff
- handcrafted
- lovebugjunkie
- Model of CNC Machine: Romaxx HS1
Great work handcrafted.
I just did my first lithopane tonight out of .250 corian. I was not really happy with the result.
Mind sharing your tool settings, speed and type of bit you are using? Interested in your cut depths, from your examples and others in the forum I think I am cutting too deep. I also had what looked like “chatter” marks on some edges, but I think I was too fast for the size. I was trying BSImages suggestion on a 45 degree v bit, but I think I'm off on some of my settings, going to give it another try tomorrow.
George
George
- Model of CNC Machine: shobot 48x96
LBJ here is a link http://www.cnczone.com/forums/showthrea ... 90&page=14
( entry #162 ) to picture with settings I used , again I use 30 degree bit and cut .2 deep ( I set zero on top of work material .25-.23 thick) I set up tool as .017 ball nose
- joecnc2006
Re: lighting up ...this is fun stuff
Joe
http://www.joescnc.com
Joe
- lovebugjunkie
Give aways
Handcrafted-
Are you giving away just the lithopane or mounted and lighted ones?
