My first litho in awhile.
Postby woody53 » Tue Jan 17, 2017 3:18 am
Did this this weekend and haven't done a litho for awhile. This is my dream car and I guess I will keep dreaming. Its a 32 Ford 5 window coupe. Will make the box this week and keep for myself. Sure don't make Me anything very often.
Dave
woody53
Model of CNC Machine: Probotix Meteor 25 x 50
Re: My first litho in awhile.
Postby dwilli9013 » Tue Jan 17, 2017 3:29 am
Definitely a sweet ride hard to beat the five window. And the old school open fender look works well.
I always thought I wanted a 23 t-bucket until I actually got to drive one. Little rough for this 6'6" frame not to mention the 350 pound frame.
Thanks for sharing sweet Litho.
D-Dub
Dwayne
Dwilli
dwilli9013
Postby Joe Duplessis » Tue Mar 21, 2017 5:48 pm
Your lithophane looks great. Would you tell me what material you used along with bits that were used and speeds that were used. I guess I am asking how you set up to do a lithhophane. I tried one of my pet dog that has passed away but it didn't come out very well. I can never find out all the details on cutting a lithophane and getting result that are posted on the forum. :(
Joe Duplessis
Model of CNC Machine: CNC Shark Pro Plus HD
Postby martin54 » Fri Mar 24, 2017 2:04 pm
Joe, that's basically because there are to many variables that come into play, the only real way for you to get repeatable good results is to do your own experimenting & work out what works best on your machine using your tooling :lol: :lol:
Take the type of tool, speed & feed info from other peoples posts & use this as your starting point to fine tune your own machine. It is also worth noting that the photograph you use will make a big difference as well. Most people will do some photo editing before they import the picture to toolpath.
The material is probably Corian but that is just a trade name, Corian is a solid surface material & there are a lot of other brands that you can use. Try a search for solid surface material & you will get a lot of other names for materials that will work for this sort of thing.
Postby Joe Duplessis » Tue May 09, 2017 6:50 pm
Thank Martin for your reply. I have some corian in the shop and will have to try doing a lithophane on it. What I am trying to do is o a lithophane to be inserted in beer clock and have the light projected through the lithophane. Don"t know if it will work. Thought maybe frosted cast plexiglass might work better than the corian since it is quite a dense material.
Joe Duplessis
