Two become one Lithophane.
Postby tonydude » Sun Nov 27, 2016 6:54 pm
Lithophane I made using photo vcarve. I used a .0625 ball nose bit carving .15 deep.
tony
tonydude
Re: Two become one Lithophane.
Postby dwilli9013 » Sun Nov 27, 2016 7:46 pm
Nice work. Always loved the lithophanes.
I create them quite frequently on my 3d printer.
Actually the effects are quite similar.
Thanks for sharing.
D-Dub
Dwayne
Dwilli
dwilli9013
Postby frank taylor » Mon Nov 28, 2016 2:29 am
what method do you use to 3d print a Lithophane have not heard of that one ????
frank taylor
Model of CNC Machine: bravoprodigy be3030
Postby dwilli9013 » Mon Nov 28, 2016 2:56 am
frank taylor wrote:what method do you use to 3d print a Lithophane have not heard of that one ????
Exact same method except my 3d printer is additive in that it builds the lithophane in layers.
While the CNC is subtractive and cuts the material down in layers.
One plus with the 3d printed lithophanes is I have a ton of colors to chose from.
D-Dub
Dwayne
Dwilli
dwilli9013
Postby frank taylor » Mon Nov 28, 2016 3:31 am
are you using photo vcarve then saving to stl. file???
frank taylor
Postby dwilli9013 » Mon Nov 28, 2016 4:12 am
frank taylor wrote:are you using photo vcarve then saving to stl. file???
No I actually use simplify 3d for processing my stl files and a rider program from thingiverse for lithophanes.
I have not tried a lithophane in Vcarve as yet. Been looking at getting photo Vcarve for that reason though..
D-Dub
Dwayne
Dwilli
dwilli9013
Postby frank taylor » Mon Nov 28, 2016 6:11 am
have a look at Ransen Photo to mesh software on the internet you can 3d print lithos onto cups or vases save as stl file cheap to buy think i will give it a go
stl files imported back into vcarve could do some interesting work in wood me thinks
frank taylor
Return to PhotoVCarve - Gallery
