Second photo, first two rail sweep.
Postby mwwock » Sun Jun 05, 2016 5:43 am
A friend's father passed away so I snagged this pic off of his Facebook feed and sent this to him.
Cut at .035 depth, 1/8 ball nose, 8%, 65 inch per minute, double crosshatch at 60 degrees. Put two coats of sanding sealer, then four hand wiped coats of burnt umber glaze, let them dry a few minutes before wiping off, wait 15 minutes between coats. Then light sanding with 220 grit sandpaper and two coats of lacquer.
mwwock
Model of CNC Machine: Laguna Swift With 4th axis
Re: Second photo, first two rail sweep.
Postby esteeme1 » Sun Jun 05, 2016 11:11 am
That looks very nice! The detail really l pops with the finish you used.
Jim Darlas
"Can Do!"
http://www.esteemedwoodcrafts.com/
http://www.esteemedplaques.com/
esteeme1
Model of CNC Machine: Cobra 404 ATC; ROMAX WD-1; Shark
Postby BArnold » Sun Jun 05, 2016 5:08 pm
Nice work all around! Great use of texture and the finish process topped it off.
BArnold
Model of CNC Machine: SO2/XCarve hybrid w/NEMA23 on all axes
