litho key chain
litho key chain
Postby deadgoodcharlie » Thu Mar 12, 2015 6:28 pm
This is our grand daughter, did this a while ago just to dry. Never did one so small .
deadgoodcharlie
Re: litho key chain
Postby MTSO » Thu Mar 12, 2015 7:35 pm
WOW. what size cutter did you use for this?. It would make a great little business card.
regards
Brian
MTSO
Model of CNC Machine: salecnc XJ1224
Re: litho key chain
Postby deadgoodcharlie » Fri Mar 13, 2015 10:19 am
Thanks Brian I used a 30 degree vbit 1/8 shank but in the software I put in .030 ballmill
deadgoodcharlie
Re: litho key chain
Postby Phil » Wed Mar 25, 2015 2:13 pm
Great job. What are the dimensions; Th x W x L?
Phil
Phil
Re: litho key chain
Postby deadgoodcharlie » Wed Mar 25, 2015 9:41 pm
The material is sign plastic and its a cast plastic. It's .125 thick x around two inches by one and a half inch , somewhere around that. I may try one even smaller and see how small you can go before the detail is gone lol.
deadgoodcharlie
