dollar store wood boxes
Postby deadgoodcharlie » Thu Mar 12, 2015 6:17 pm
these boxes are great for holding your lithophanes some have a plastic window in the top so your lithos would have to be based around that size opening.This box did not have the window so I unscrewed the lid and cut one out.
deadgoodcharlie
Re: dollar store wood boxes
Postby deadgoodcharlie » Thu Mar 12, 2015 6:18 pm
deadgoodcharlie wrote:these boxes are great for holding your lithophanes some have a plastic window in the top so your lithos would have to be based around that size opening.This box did not have the window so I unscrewed the lid and cut one out.
Also forgot to mention that I lined the sides and back with foil tape.
deadgoodcharlie
Postby MTSO » Thu Mar 12, 2015 7:31 pm
I was going to comment on how bright the picture looked. Are you able to post pictures of the light set up and the inside of the box?.
Regards
Brian
MTSO
Model of CNC Machine: salecnc XJ1224
Postby deadgoodcharlie » Fri Mar 13, 2015 10:21 am
Sure I'll post a pic some time today very simple but this setup has no on off switch as of yet.
deadgoodcharlie
Postby mikeacg » Fri Mar 13, 2015 12:35 pm
Thanks for the heads-up on the boxes! I'll check them out today! I still haven't tried a Lithophane but I'm getting closer...
Mike :)
mikeacg
Postby deadgoodcharlie » Sat Mar 14, 2015 3:02 pm
Here you can see the foil tape and the led strip.
inside the box
deadgoodcharlie
Postby Makingtoothpicks » Fri Mar 20, 2015 2:29 am
I have a Dollar type store nearby I will look and see if they have boxes. I see wooden boxes on Amazon for around 3 to 5 dollars depending on size.
I may try one or 2 for my V-Carved acrylics.
Don
Makingtoothpicks
Model of CNC Machine: Cncrouterparts CPR2448
Postby deadgoodcharlie » Fri Mar 20, 2015 1:03 pm
Sounds good Don , waiting to see how they work out for you.
deadgoodcharlie
