I used a .0625 ball nose bit carving .12 deep with a rpm of 16,000 and feed rate of 80 ipm. The size of corian is .25 thick and measures 3.75 inch wide x 3.125 high and took 1-3/4 hrs.
Tony
Night light lithophane
Re: Night light lithophane
Is that plugged straight into a socket Tony??
Martin,
This is what I use for all my night lights. http://www.klockit.com/products/dept-27 ... -clip.html
Tony
Tony
Thanks Tony, never really thought about actual night lights even though you said that's what it was in the title
I always thought this sort of thing was just for display purposes, still haven't got round to making one although having a few problems with wood photo carving.
tonydude919 wrote:I used a .0625 ball nose bit carving .12 deep with a rpm of 16,000 and feed rate of 80 ipm. The size of corian is .25 thick and measures 3.75 inch wide x 3.125 high and took 1-3/4 hrs.
Tony
