For a friend
- Model of CNC Machine: Probotix Meteor 25 x 50
For a friend
Did this yesterday and took WAAAAAAAAAAAAY too long. Is 4 1/4 x 4 3/4 and took 9 1/2 hours @ 100 IPM. Z movement was continuous, so that was the reason. Came out perfect very detailed.
Re: For a friend
Beautiful, lot of detail. What bit did you use that took so long?
Tony
Tony
Re: For a friend
A 1/32 tapered ballnose, Tony. But I'm sure it was the enormous Z movement that slowed it down. You can see every little skin wrinkle and they are all carved, LOL.
- Model of CNC Machine: shopbot buddy bt 32
Re: For a friend
Woody , I only use that size of litho's that are 2"x 3" or 2" x 2" , everything else I use 1/16" tapered ball nose , good luck Pop's
POPS1964
SHOPBOT Buddy BT-32
SHOPBOT Buddy BT-32
