first photo in aluminum
Postby captaingrayhair » Mon Aug 20, 2012 4:35 pm
Any feedback, good or bad would be great. Approx. 6" x 4", aluminum.
60 degree V-bit w. .005 flat. Max cut depth .030 in 1 pass, coolant on.
Scotch-brite surface, then filled w/ black ink, then scotch-brite again till result.
Keep on keepin" on!
captaingrayhair
Model of CNC Machine: bridgeport cnc
Re: first photo in aluminum
Postby GaryR6 » Mon Aug 20, 2012 10:27 pm
Nice....never thought of using aluminum for a pic.
GaryR6
Postby captaingrayhair » Mon Aug 20, 2012 11:40 pm
Thanks. Not sure which is nicer, my machining or the girl. I've done a few wood photos
with not great results. I'm sure it's me, my forte is metal so I thought id' try it. Next is brass.
Check back soon! Hey man, I was born and raised in AZ. Now live in Victoria, B.C. Cheers!
Keep on keepin" on!
captaingrayhair
Postby mikeacg » Tue Aug 21, 2012 3:22 am
I've done that with my laser but am glad to see you do it with the CNC! Gives me some good ideas!!
Mike
mikeacg
Postby lseguine » Sat Jan 19, 2013 3:33 am
great looking job.. i also work in metal mostly jewlery type stuff. would like to talk with you more in deepth on what you are doing and the machine you are working with.
i'm running a home built sheen wit moch3 and home made drivers. am stuck right now with a small working area (4"x11")
but that lets meplay for now.
really like the looks of your piece..
Larry In Alaska boonies
lseguine
Model of CNC Machine: home made grizzley 8689 mini mill
Postby metalworkz » Sat Jan 19, 2013 4:14 am
Hello,
That turned out very good! Thanks for posting it and for sharing the details. Seems I need to try some different things with metal.
Best regards,
Wes
wes.spence@comcast.net
Gingery Machines:
Lathe, Horiz. Mill, Shaper, Leaf Brake
metalworkz
Model of CNC Machine: SX3 CNC, DIY 24x20 & 48x60 routers
Postby Xxray » Sat Jan 19, 2013 8:29 pm
Hey how'd you get a pic of my wife ??
Just kidding, looks nice, lines are a bit annoying but I suppose it looks better from a little distance. Could you drop stepover to reduce the lines a bit ?
Doug
Xxray
Postby Navigator7 » Sat Jan 19, 2013 10:04 pm
Xxray wrote:Hey how'd you get a pic of my wife ??
Your wife????
Besides, all women look better from a distance!
You see one up close...you want to see them all!
Aluminum...how cool!
My wife (ahem) has what appears to be a ceramic fired, tea candle lamp shade that has the qualities of photo V-carve.
The candle light makes the lamp shade come to life.
Its circular and tapered at the top like a conventional shade. Damned if I can figure out how they made it.
Its like it was cast.
"If you’ve got a business, you built that. Nobody else made that happen."
Navigator7
Model of CNC Machine: ShopSabre
