Marilyn
Marilyn
Postby BrianM » Thu Jan 26, 2006 12:05 am
These images are of a test piece we cut in brass on a Roland EGX-600 desktop engraving machine. The piece of brass is about 75mm (3") high.
Please click on the thumbnails to view higher resolution images, due to the lines in the engravings the small thumbnail exhibit patterning that isn't there when the pieces are viewed in the 'real world'
Original photo - low res jpg downloaded from the web
(29.77 KiB) Downloaded 1272 times
Piece on machine after cutting. Note relatively little contrast between cut areas and unmachined areas.
(160.66 KiB) Downloaded 1223 times
Here we have applied 'blackening fluid' all over the brass piece, you could also use a paint such as enamel
(113.81 KiB) Downloaded 1178 times
The brass piece after a minute or so's polishing with 'wet and dry'. The blackening remains in the grooves but is easily removed from the flat surface. The photos don't do the piece justice unfortunately
(133.64 KiB) Downloaded 1558 times
BrianM
Vectric Staff
Re: Marilyn
Postby bogusz87 » Thu Jun 06, 2013 9:30 pm
good job
website:
www.portretywdrewnie.pl
bogusz87
Model of CNC Machine: INFOTEC
Re: Marilyn
Postby Ms Wolffie » Thu Jun 06, 2013 10:08 pm
I don't remember ever seeing these images before but, after checking the posting date,well, that is not surprising.......
Pity, I may not have given up on PVC if I had seen these first.
Cheers
Wolffie
Cheers
Wolffie
Whatshammacallit
Ms Wolffie
