These are my pictures in wood
Re: These are my pictures in wood
Postby martin54 » Fri Apr 10, 2015 1:23 am
Xxray, are you using PVC or Aspire to do this sort of thing?? Might be that in Aspire the toolpathing is different.
Postby Xxray » Fri Apr 10, 2015 6:41 am
Well all I can say it what I observe ,,, If its such a minute amount that it isn't even perceptible, I don't consider that a lift.
Doug
Xxray
Postby Xxray » Sun Apr 12, 2015 6:27 am
You are right it does retract, I got mine set to .10 so not much, but retract after each line it does.
Doug
Xxray
Postby MTSO » Fri May 01, 2015 10:49 am
here is a project I did recently, the finish is a epoxy resin, look very much the same as what has been used in this thread I used ACABADO BRILLANTE.
Regards
Brian
MTSO
Model of CNC Machine: salecnc XJ1224
Postby weber765 » Tue Jul 07, 2015 4:53 am
Thanks for sharing the ACABADO BRILLANTE finish you used it certainly looks like you hit it spot on to me and I will sure give it a try.
Glenn
weber765
Model of CNC Machine: home built and modified Vytek rebel
Postby jamesr » Thu Jul 09, 2015 6:35 pm
Please tell me how you did this. I have an Inventables X-Carve and I have loaded Java and UGS on my computer. When I go to Vcarve photo tutorials and try to carve their sample photo's my machine only skims the wood. I have looked at their video's and have set my machine up just as they say. Also yesterday my machine went from skimming a photo sized area to only carving a 1 inch by 3/8 inch area and it is still doing that today. I have made sure I have inches in vcarve and inches in my UGS check marked. I am at a loss as where to go from here. Can you help?
jamesr
Model of CNC Machine: Inventables 1000mm X-CARVE
Postby jamesr » Fri Jul 10, 2015 12:31 am
I could sure use your help. I have the Inventables X-Carve and I am trying to carve photos using the v carve photo software and UGS. Using their (v carve photo) photo I tried to carve the woman photo, my machine carved from the bottom right to the top left at a 33 degree angle (set at .02 inch depth per v carve suggestion) and all I got was angled lines. Nothing resembling a photo at all. No texture, no depth, no anything. If you can give me any guidance here it would be greatly appreciated.
jamesr
Postby weber765 » Fri Jul 10, 2015 2:48 am
To make the photo appear you will have to add a stain or paint and then lightly sand the surface to show the contrast. Have you done that yet ?
weber765
Postby keralesh » Sat Jan 16, 2016 4:02 pm
WoodArt wrote:Here are some of the wood pictures i have made...hope you like them :D
http://www.youtube.com/watch?v=-a-fv0GOMtQ
http://www.youtube.com/watch?v=gY-kEWoPB_Q
http://www.youtube.com/watch?v=_HWe-djr-G8
Best regards,
/Markus Dahlberg
What type of wood do you use and how thick? Thanks
keralesh
Model of CNC Machine: 6040Z 1500W 4 Axis CNC Router
Postby martin54 » Sat Jan 16, 2016 5:44 pm
Keralesh, you would be better starting a new thread to ask your questions as the guy that first posted on this thread hasn't been on the forum for years
Previous
