These are my pictures in wood
Re: These are my pictures in wood
Postby pops1964 » Tue Aug 12, 2014 12:31 am
Hello, I'am really impressed with your work . I due 3-D , and a ton of 3-D carvings and have been asked to do one on wood for a memorial for my uncle could you pass along some tips ? Would be much appreciated . thank you
POPS1964
SHOPBOT Buddy BT-32
pops1964
Model of CNC Machine: shopbot buddy bt 32
Postby pops1964 » Tue Aug 12, 2014 2:55 am
Markus and I do alot of lithos but need help with wood pvc
POPS1964
SHOPBOT Buddy BT-32
pops1964
Postby antennasDIY » Wed Feb 18, 2015 3:51 am
WoodArt wrote:It was a creative weekend :)
http://youtu.be/M2OX1qhBWVM
Take care
/Markus
I have a picture of my boy just like that and would love to cut it like you did. Any help with your settings??
antennasDIY
Model of CNC Machine: Home made
Postby martin54 » Wed Feb 18, 2015 1:53 pm
Take care
/Markus
Settings used are mentioned on the first page of the thread but it would appear to be the finishing technique Markus uses that gives such good results & unfortunately for us he has chosen to keep those to himself, cant say I blame him though.
Postby antennasDIY » Wed Feb 18, 2015 3:00 pm
Ok no sweat. I thought there might be more than that, as I did see something on the first pages.
Ok no problem, challenge accepted!! LOL..
antennasDIY
Postby MTSO » Thu Feb 19, 2015 1:08 am
Hi Markus
do you get any cupping, twisting or bowing of your material when you have finished carving on one side?.
regards
Brian
MTSO
Model of CNC Machine: salecnc XJ1224
Postby Xxray » Thu Feb 19, 2015 3:28 am
The guy hasn't posted in years and wasn't inclined to share much info when he did, think its a lost cause.
He appears to use a technique where he paints/stains the wood then sands off the high spots or maybe rubs it off before it dries, leaving the lower spots darker than the surrounding areas.
One of us will figure it out and share, I've done a lot of lithos but so far haven't set my sights on wood.
Doug
Xxray
Postby kristenanne77 » Wed Apr 08, 2015 6:40 pm
WoodArt wrote:I'm sorry i called them V-bit's :oops:
I use engraving tools with a flat tip of lets say 0.3mm
I then change the settings in the line spacing box so i get the "distance between lines" to approximatley the flat tip diameter. When i do this i remove the material.
Look at the screendump i have attached.
Any help?
/Markus
I also cannot get the width of the line spacing to be close to the width of the engraving tip.
I would think that no matter what size the engraving tip is, ...once it is inserted the width will get wider, because it has an angle.
The individual lines can only stay the same width if it was straight like an endmill. But the engraving bits , although flat on the bottom, start to widen as you go up from the tip.
So that part confuses me. Also the picture shows a side angle of 30 degrees, but you label it as 15 degrees.
Do you put in "incorrect values" to make the program get (close to) the result you want?
Another piece of the puzzle that I am trying to figure out is what setting you have for your rapid z movement. If it set at any distance above the z plane, it would not produce a smooth surface, as it would be floating over the surface at certain points (where you would normally have a rapid z movement). I can only see a "surface planning or skimming' happening if the z rapid movement was set to 0 so it would not float above the surface during this movement. You do some great stuff which I also would like to do ... just trying to put the pieces together.
Would appreciate any advice.
(my only other alternative would be to start dealing with other software programs which would convert the darkness of grey scale picture into a corresponding depth using a type of user defined "darkness to depth" scale to produce a sort of relief map for a photo. If I can do a good jod with this ... I will be very happy and can save up for a Vcarve instead!)
K
kristenanne77
Model of CNC Machine: ShapeOko 2
Postby JJWMACHINECO » Thu Apr 09, 2015 2:27 am
kristenanne77 wrote:(my only other alternative would be to start dealing with other software programs which would convert the darkness of grey scale picture into a corresponding depth using a type of user defined "darkness to depth" scale to produce a sort of relief map for a photo. If I can do a good jod with this ... I will be very happy and can save up for a Vcarve instead!)
K
That's the same thing PhotoVcare does. It calculates depth of cut from 8bit grayscale. if it's a 24bit color image, it converts it to a 8bit grayscale image for it's calculations of the depth of cuts. It's no different then the other software your talking about.
Extensivly Re-worked/Re-designed/Modified Servo K2CNC KG-3925 and the Mini Laser Engraver
JJWMACHINECO
Model of CNC Machine: Re-worked/Modified K2CNC KG-3925
Postby kristenanne77 » Thu Apr 09, 2015 2:45 pm
K
That's good to know. Its gives me a better understanding of the software.
It still doesn't produce a continuous "top (lightest shade) to bottom (darkest shade) carving though, because of the pecking from the rapid z movement.
Perhaps setting my zero starting depth at about 0.5 mm deep (instead of zero) might help?
Now .... I guess its a bit of experimentation with different settings and bits.
I am going to try using engraving bits with a very small angle.
Any other tips to make it appear as a "smooth" carving " would be appreciated.
K
kristenanne77
Postby JJWMACHINECO » Thu Apr 09, 2015 9:01 pm
The other software your talking about does not retract at the edges on each pass. It only reverses cutting directions until it's finished, then it retracts.
Good luck.
JJWMACHINECO
Postby Xxray » Thu Apr 09, 2015 9:13 pm
I haven't noticed mine retracting after each pass, must be something in your setup
Doug
Xxray
Postby JJWMACHINECO » Thu Apr 09, 2015 10:31 pm
Retract is "Rapid clearance gap" and it can not be set to a value less then .0001". That is from Z axis zero. It retracts there on the edges of every pass before reversing, in my experience with PVC.
JJWMACHINECO
Postby Xxray » Fri Apr 10, 2015 12:07 am
Mine doesn't, it goes from 1 line to next cutting not retracting at all.
I'll scrutinize my next cut to be sure. The only time I recall Z lifting was/is when max depth per pass in tool properties is set lower than the thickness of material, then it would lift and do another pass on the same line. I found that unnecessary and just changed max depth to material thickness.
Doug
Xxray
Postby JJWMACHINECO » Fri Apr 10, 2015 1:12 am
Look in the Gcode file for the G00 ZXXX and then the G01 linear moves afterwards at the edges where it reverses directions.
JJWMACHINECO
PreviousNext
