These are my pictures in wood
Postby WoodArt » Fri May 18, 2012 9:02 pm
Here are some of the wood pictures i have made...hope you like them :D
http://www.youtube.com/watch?v=-a-fv0GOMtQ
http://www.youtube.com/watch?v=gY-kEWoPB_Q
http://www.youtube.com/watch?v=_HWe-djr-G8
Best regards,
/Markus Dahlberg
WoodArt
Model of CNC Machine: Heiz high z 1000T
Re: These are my pictures in wood
Postby tonydude919 » Sat May 19, 2012 1:32 am
Great pics. They came out great. Can you tell me what bits you used and the settings that you used?
Tony
tonydude919
Model of CNC Machine: cnc mako shark extended bed
Postby JJWMACHINECO » Sat May 19, 2012 2:58 am
Very impressive. Details of your process???
Jeff
Extensivly Re-worked/Re-designed/Modified Servo K2CNC KG-3925 and the Mini Laser Engraver
JJWMACHINECO
Model of CNC Machine: Re-worked/Modified K2CNC KG-3925
Postby WoodArt » Sat May 19, 2012 6:02 pm
Thanks for the kind words.
Jus finished this one
http://www.youtube.com/watch?v=-CFBlqgqzIw
For small detailed pictures i use 0.2mm V-bit's
For medium 0.3mm
And the large i use 0.5mm
I also have the line spacing as vide as the v-bit i use so i remove all the material and get a 3D-surface corresponding to the picture.
The real difficult part was to find a surface finishing method that delivers these kind of results 8)
Best regards,
/Markus
WoodArt
Postby Ms Wolffie » Sat May 19, 2012 9:55 pm
Love it
Cheers
Wolffie
Cheers
Wolffie
Whatshammacallit
Ms Wolffie
Postby rrrevels » Sun May 20, 2012 9:32 pm
I could get interested in photo carving like this. Those are great. I am going to have to save up for photocarve.
Beautiful!
Russ
CAMaster MC3050-R w/steppers and Mach3, Aspire 8.02 D&C Series 1A &1B - Wildlife Scenes
rrrevels
Postby bullhead » Mon May 21, 2012 8:07 am
How do you get zero spacing between the the lines with the slider control. Are you using a different bit than you are selecting. Iv'e been experimenting with this and can't get 0 between the lines and make a smooth surface. I've tried using a different bit than selected and gotten close. I'm running out of scrap wood and sure would appreciate the ultimate tip. Thanks in advance for any info you wan't to share.
bullhead
Model of CNC Machine: shark
Postby patmcl » Mon May 21, 2012 4:30 pm
I'm not sure I follow the line spacing as being the same as how wide the v-bit is. Can you explain this a little more for me. Being in North America here our bits are still sold in imperial messurments. What is a .2 mm bit I have not seen them before. Also what types of finishes are you using this worrk is very nice. I know it takes a while to get that kind of quality but any suggestions from you would be great.
Pat
Learning by trial and error or with the help of others is still learning and a great addiction!
patmcl
Model of CNC Machine: shop bot
Postby WoodArt » Mon May 21, 2012 8:38 pm
I'm sorry i called them V-bit's :oops:
I use engraving tools with a flat tip of lets say 0.3mm
I then change the settings in the line spacing box so i get the "distance between lines" to approximatley the flat tip diameter. When i do this i remove the material.
Look at the screendump i have attached.
Any help?
/Markus
WoodArt
Postby WoodArt » Mon May 21, 2012 9:47 pm
I think that this one i made a few days ago turned out really nice :)
http://www.youtube.com/watch?v=S3kQciKHZq8
Best regards,
/Markus
WoodArt
Postby Joe Crumley » Tue May 22, 2012 12:48 am
Is this a business venture or just a hobby?
Joe Crumley
Postby patmcl » Wed May 23, 2012 12:25 am
Very very nice work, I hope that I can get results like this or even half as good. I have my first grandson that I will be meeting in two months and would love to get images looking like this. Feed me more info I'm hungry LOL.
patmcl
Postby sawmiller » Wed May 23, 2012 12:47 am
i think the same results could be had with a small ball nose just like a lithopane, just dont invert it.
dan
In the heart of Tn
sawmiller
Model of CNC Machine: joe's rack and pinion hybrid
Postby Bob Reda » Wed May 23, 2012 3:58 pm
How deep are you cutting these?
Bob
Bob Reda
Postby WoodArt » Fri May 25, 2012 11:08 am
It's just a hobby at the moment but i had serious plans on going "big" with these pictures at the beginning of this year but a joboffer that i could not turn down came to me.
I still am absolutley shure that it would not be a problem at all making a good living out of selling these products. It's a unique gift and the customers are totally happy with what i deliver. Maybe i will take this to the next level but that involves a lot of different steps......
I cut these pictures at a maximum cutting dept of 1mm, if you look close at the attached picture where i show the engraving tool you see the 1mm setting :wink:
Take care,
/Markus
WoodArt
Next
