my new litho
my new litho
Here is my new litho. It is 5x7 inches 1/4" corian. Used .125 ballnose for rough and .0625 ballnose for finish. Took 3hrs total cut time.
Tony
Tony
Re: my new litho
That really looks great Tony. I have PhotoVCarve but have not used it yet. Can you give me your settings and I will try to carve a piece of 5x7 1/4" Corian. Again, that is a job well done.
Gary
Gary
Re: my new litho
Gary,
My settings for rough cut is .117 deep 20 percent stepover, feed is 80 rpm is 16,000
finish cut is start depth is .05, cut depth is .117 feed is 80 inch per minute
Re: my new litho
Thanks Tony. I plan to cut mine this weekend. I hope it turns out a good as yours did.
Gary
Gary
- dhellew2
Re: my new litho
Nice job. It appears you back-lit yours. Did you use LED's? Did you use a diffuser? Dale
Young = time, no money
Old = money, no time
Dale
Dale
Re: my new litho
Looks great Tony. What do you use for a power supply for the LEDs?
Phil
Phil
Re: my new litho
These are the power supplies I use.
BPS-12VDC-AA: Portable 12VDC 8-Cell Battery Power Supply - 8 x AA
CPS-12VDC-xW: 12VDC CPS series Power Supply
http://www.superbrightleds.com/cgi-bin/ ... bps#Table9
Hope this helps.
Tony
Hope this helps.
Tony
Re: my new litho
Thanks again Tony.
Phil
Phil
- PeteC
- Model of CNC Machine: Probotix FireBall Comet
Re: my new litho
Great job Tony! May I ask, where do you get the corian? I'd like to get some but I find that they are pricey. I just like to find the best price for some corian so I can make some & get my feet wet. Thanks,
Bigfoot
Re: my new litho
I get mine from eBay http://www.ebay.com/itm/3-Pcs-1-4-x-8-x ... 828wt_1002
He's on vacation till March 22
